http://www.ka24der.com/
Supercharger vs. Turbo
There are many things one should consider when deciding what is the right setup for their application. First off, peak HP and TQ isn't everything. The M62 superchargers yield usable power that is noticeable all throughout the powerband, but especially at low to mid range RPM's. This is due to to inherent properties and efficiency of the Eaton M62 roots-style supercharger and 2.4L KA24DE motor combined together.
Here are a couple selling points to put it in perspective:
Powerband is similar to a small stock V8 but much cheaper
Yields more power and torque down low compared to small, medium and large turbo setups
Associated parts are readily available and replaceable unlike most JDM motor swaps which can be problematic to source parts quickly and conveniently
Compared to most turbo setups, installation is easier and maintenance time is reduced
Because supercharger whine is awesome
Applications
The KA24DER.com kit is intended for 91-98 Nissan 240sx's with the DOHC KA24DE engine. The kit is not guaranteed to fit ABS-equipped models due to supercharger inlet elbow placement inevitably conflicting with the ABS unit.
Who Will Benefit
A supercharger kit is not for everyone, but on the flip side, nor is a turbo kit. Below are some of the platforms we believe the supercharger kit would be advantageous towards:
Daily drivers
Drifters
Autocrossers
Road racers
Typical Gains
Dyno SheetAt 10 psi, we recorded 255 wheel horsepower and 249 ft.lbs. This is an estimated 120 horsepower increase at the wheels compared to stock. But like anything else, there are many variables that come into play. Results may vary depending on motor condition, compression ratio, pulley used and resulting boost level, ecu tune, type of cams used and if headwork is done, exhaust system setup, gasoline used, elevation, dyno utilized, etc.
The kit includes the following components:
1/2" thick 6061 aluminum CNC machined adapter plate between the supercharger and stock upper intake manifold assembly; intake ports are radiused; three 1/8" NPT ports for vacuum/boost signals; provisions for stock AAC valve and air regulator; includes the stock Nissan gasket between the supercharger and the adapter plate
1/2" thick 7075 aluminum CNC machined alternator relocation bracket; includes pullies, tensioner and drive belt
6061 aluminum 3" intake pipe assembly setup for use of a Nissan Q45 throttle body; slip-style recessed CNC machined flange/tube assembly allowing for easy installation and access to bolt heads; 1/8" NPT port for actuator signal line
6061 aluminum Q45 throttle body cable bracket (bolt-on)
All necessary hardware and gaskets for installation
Detailed installation instructions
Here are some of the other items you will need to buy or prepare for:
Eaton supercharger from a 2002-2004 Nissan Xterra or Frontier (from the 3.3L V6); the supercharger inlet will need to be ported to our specification and gasket matched; the bypass valve butterfly casted housing will need to be machined down to create a sufficient air gap between it and the adapter plate; the first 4 cooling fins (closest to the pulley) on the supercharger housing will need to be machined down flush if you plan on using a stock style oil filter; otherwise an oil filter relocation will be required for proper clearance
Nissan Q45 82mm ID throttle body (from the 4.5L VH45DE motor)
The stock mafs HP/airflow potential is very limited; to take advantage of full airflow potential through the mass air, we recommend you using a Q45 mafs as its resolution and airflow limit is more suited for the supercharger kit
Relocation of the battery to the trunk will be necessary as the intake pipe needs to be routed in its path down towards the passenger side fenderwell (may need to cut the battery tray with a holesaw to create room for the pipe to pass through)
We recommend at least 370cc injectors for boost levels up to 10 psi on gasoline; beyond that, an injector upgrade will be required; you may also want to upgrade your worn out factory fuel pump with a DeatschWerks 300+ LPH fuel pump for more safety margin as well; for E85 applications, plan on a minimum injector size of 550cc
Factory fuel and ignition maps will not be appropriate for the supercharger kit; we recommend either a custom ROM tune (Nistune or Calum) or purchasing a standalone (AEM, Haltech, Motec, etc.) and then having your car professionally dyno tuned; contact us through the form on the left if you have interest in having your car tuned by us or a recommended professional
