Super Tuner Motorsports
cvc9216
Anybody using their mounts? They keep pushing back the release date and I keep asking for pictures, but they don't have any. I don't want to buy without seeing pictures. Anybody have pics of the mounts or an installation using them?
Joe
**** STMthey are screwing a friend and myself right now
their mounts are drilled wrong and their "7 day turnaround" on the wiring has just entered its 5th week
krayton
yep, tooks us about 2 full days to re-drill their mounts just to work.
theres a lot more problems, but not to sure if we wanna go over them right now, but we will soon
i'll also get pics when we figure what we're gonna do
rb250sx
Car: '89 s13 w/ RB25DET
'07 Nissan Frontier
'14 Jeep Rubicon
I purchased their mounts. Im still waiting for my engine though so I havent been able to try them. What other problems are there with the mounts other than the holes are drilled wrong? PM me or send me a message on AIM if you wish: VaultGod
btw, i have pictures of the mounts here:http://filebox.vt.edu/users/dafritz/
Joe
they said the mounts would move the engine down then back 1.5 inchesdosent move the motor down more than .2 inches and dosent move it back at all.
S13Sil-line
Car: Full throttle-*** out sideways
From what I understand kamin is using an RB20 transmission on a rb25 using the STMS kit. Its made for the rb25 motor/transmission. The Rb20 transmission is different.
Joe
lets get something straight
the RB20 transmission has the SAME bolt up problems as the RB25 when you use the r33 crossmember. shifter is 1.5 inches too far forward and the mount dosent line up.
AND those problems i speak of were NOT RELATED TO MY CAR. they were related to my friend i mentioned above. rb25 transmission and motor.
even if it did matter, the motor still dosent move the 1.5 inches back they promised. and that has nothing to do with the transmission.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
THOSE MOUNTS ARE PRETTY GHETTO, I COULD MAKE THOSE IN MY BACKYARD. KAMIN IS CORRECT THE MOTOR MOUNTS DETERMINE WHERE THE transmission SITS. ALTHOUGH THAT KIT IS DESIGNED FOR THE RB25 transmission IT SHOULD WORK WITH THE RB20 transmission.
S13Sil-line
I should have checked before I said something. I thought the Rb20 tanny had different mounts than the 25 transmission. I apologize. They say they are using the same kit for there car and I saw pics of it and it all looks legit. Could be wrong.
cvc9216
Well this is bad news. I guess I'll have to go with Mickinney mounts after all. Damn, maybe I shouldn't have just spent $2200 on wheels.
PROJECTRB240SX
ITS CROSSMEMBER DESIGN THAT IS DIFFERENT.
PROJECTRB240SX
WHY DO YOU WANT MOUNTS?YOU DON'T NEED THEM.
cvc9216
I don't want to have to cut the hood, or spacer the sway bar, or anything like that. I was considering making my own mounts, but I don't have time right now, I'd like to get it running soon. I was going to use stock mounts for now, then make my own later, but then I realized the driveshaft will be too long.
S13Sil-line
Ok. music....Clear things up for me. Name every problem that will occur if I dont use any mount kit. Please.
cvc9216
Ideally, I'd like mounts that use the stock RB crossmember and isolators, like STM's. That seems like the easiest and most failsafe method to me.
PROJECTRB240SX
HOOD SKELETON WILL HIT THE CAM COVERTHE transmission CROSSMEMBER WILL ONLY LINE UP WITH TWO BOLT HOLES (ON RB25 ONLY)DUMP PIPE WILL RUB STEERING ARM (FREE FIX: LOSSEN THE RACK BUSHING CLAMPS AND STEERING FLEX KNUCKLE AND ROTATE THE RACK FORWARD TILL THE STEERING ARM CLEARS)GEAR SHIFT WILL SIT FORWARD ANYWHERE FROM 1/2 TO 1 1/2 INCHES FORWARD (EXAMPLE MY RB20 SITS 1/2 INCH FORWARD W/ NO CLEARANCE ISSUES OR COMFORT COMPRIMISED)
PROJECTRB240SX
YOU NEED A NEW DRIVESHAFT NO MATTER WHAT WITH THE RB25.AND THE SWAY BAR HAS CLEARANCE JUST GET YOUR ENGINE RUNNING SMOOTHLY THEN INSTALL THE SWAY BAR (IT SHOULD HAVE NO ISSUES WHAT SO EVER)
Joe
sway bar does not clear with the r33 crossmember and a rb25 motor.
ask sean about his rb25+s13 on az240.
ive never heard of the hood hitting the upper timing belt cover, mine dosent. it his the blow off valve (only the upper section)
PROJECTRB240SX
I GOT KICKED OFF BY X3600. OHH SO THE RB25 DOESN'T CLEAR? I THOUGHT IT HAD THE SAME CLEARANCE ISSUES WITH THE RB20. SO IT SITS THAT FAR FORWARD?
kevy8up
s13sil.....lemme know when u gonna swap stuff....i might wanna come over and check this out...lol no seriously.
Joe
lol
and yes it dosent clear because of the r33 crossmember, moves the motor too far forward.
PROJECTRB240SX
ON THE RB20 AND 25 I LOOKED AT IT WAS THE FRONT COVER AND THE BOV SO THEY TOOK THE ENTIRE HOOD TRIANGLE OUT.
MY RB20 HITS BOTH WE EVEN DID THE BABY POWDER AND MASKING TAPE TRICK AND THEY WERE BOTH HITTING.
S13Sil-line
Well I know super tuner has spacers to lower the sway bar. I dont know. Who has done the s13/rb25 swap. I wanna talk to them. Im tired of hearing hearsay.
PROJECTRB240SX
DUDE WHO IS DOING HEARSAY? ALL OF US SPEAKING HAVE EXPERIENCE IN EVERYTHING WE SAID. HELL EVEN ASK CAMERON HE'LL TELL YOU OR EVEN READ HIS STICKY THREAD.
S13Sil-line
No no no. Im not saying you are. There is just a lot of people talking about the swap that dont even know anything about it. You know that. Thanks for your help. I heard if you dont use the kit, the bell housing will rub the underbody of the car.
PROJECTRB240SX
THAT WAS NOT AN ISSUE IN MY CASE OR THE RB25 INSTALL I LOOKED AT, AND IF IT RUBS GENTLY TAP THE TUNNEL UP FOR CLEARANCE.
PROJECTRB240SX
ITS OK, I JUST THOUGHT THAT WAS AN ATTACK ON ME. I WILL HAVE TONS OF PICTURES SOON OF ALL MY INSTALL, WIRING, MISC CRAP, LEFTOVER FOR SALE STUFF, ETC.
S13Sil-line
Please do. What problems did you run into on the whole swap.
PROJECTRB240SX
I DID A RB20 INTO A 89 S13.
PROBLEMS I DELT WITH:
HOOD SKELETON (CUT TO FIX)STEERING ARM RUBING THE DUMP PIPE (EASY FIX)LACK OF IC PIPINGPOWER STEERING LINES (NEED CUSTOM LINES)
THATS IT. ON THIS ENTIRE INSTALL I'M IN LESS THAN $2500 INCLUDING CLIP, FAN, FILTERS, LINES, PLUGS, INTERCOOLER & PIPING, ETC.
S13Sil-line
The Rb20 block is the same sizeas the 25 right?
