Sunroof issue
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
I don't know why but I can't seem to search the word sunroof, roof, sun roof, all returning 0.
Anyway, been a while. My sunroof won't close properly. It's misaligned from left to right slightly causing condensation and water seepage. Is this an easy diy thing someone can give me directions, is it something safelight fixes, or do I have to go to the dealer?
Thanks.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Water can't come from a misaligned roof. The gasket on the pane is there to stop wind, not water. Water goes past it and into drain channels surrounding the pane, then out through 4 drain hoses (one at each corner). This might help you:
post6826946.html?hilit=sunroof%20drain#p6826946
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Sometimes search doesn't play nice.
Search found 565 matches: sunroof
Search found 53 matches: moonroof
Search found 51 matches: sunroof reset
New Owner - 2007 M45 Sport with Sunroof issue
How to reset a Infiniti sunroof that doesn’t close
Moonroof Reset Procedure.
04pathse wrote:
Thu Apr 28, 2016 10:11 pm
Try this:
INITIALIZATION PROCEDURE
If the sunroof does not close or open automatically, use the following procedure to return sunroof operation to normal.
1. Close the sunroof if it is not in the closed position. It may be necessary to repeatedly push the switch to close the sunroof.
2. Press and hold the TILT UP switch the sunroof will tilt up. Release the button.
3. Press and hold the TILT UP switch again. Do not release the switch, keep pressure on it. After 4 seconds of depressing, the sunroof will full close.
4. Initializing procedure is complete. Confirm proper operation of the sunroof (slide open, slide close, tilt up,tilt down.)
