I would make that a really slow 10 count. Recently disconnected my battery and had to reset windows and sunroof. Thought I had held the switch in the closed position long enough, but when I went to use the sunroof, it was doing that move only about 1/2 an inch for each press. Soooo, did the reset procedure again, but held the switch for a pretty long time, such that my arm was getting tired - lol that worked.svard75 wrote:Also try opening it all the way then hold the switch in the open position for a slow count to 10 and repeat while closing
that's a major switchJust Ask wrote:
Other than that I just love this car. I came out of a 2008 Jeep Grand Cherokee SRT8 with a Procharger D1 on it. Zero to sixty in 3.6 seconds in a 5,000 lb brick was fun but I got the itch to get something more docile and fuel efficient. 20MPG is a huge improvement over 12MPG...lol. Going to take the M on a road trip with the wife and son at Thanksgiving...something that was just not enjoyable in the Jeep. Thanks for the help on the sunroof issue!
I initially was thinking the same, but even when the glass is popping up and down to "vent" it has some hesitation and general rough movement. I would think that the tracks don't come into play when simply moving up and down. Besides, the tracks look REALLY clean and well lubricated. I'm not really sweating it as i can live without it for a while.The00Dustin wrote:While it certainly could be the motor, it could also be as simple as the tracks needing lubricated. I feel like someone had to do that on this forum once and posted some info, but I'd be hard pressed to find it. Nonetheless, I'd recommend looking into it before swapping the motor.
