Subwoofers & Amp installed, M45
rxmclaren7
Car: 2006 Infiniti M35x
going tomorrow to get my new sub and amp put in will post pics when completed!!
SoThrowedMex
Car: 2003 Infiniti M45 WV2 Silverstone Metallic Clearcoat on 235/30/ZR22
nice setup OP
06M4.5
Car: 2006 M45
SoThrowedMex wrote:nice setup OP
Thank you sir
banglabhai
2003 Pontiac Vibe
1991 Toyota Cressida
1989 Toyota Cressida
1978 Toyota Cressida
^^ I am from Houston too. Hit me up on my email [email protected]
Thanks.
JoshTex
Great info. So this LC2i piece from Audio Control seems to just be a Line out converter. Basically taking an amplified signal and stepping it down enough to run into the amp, correct? Obviously there are quite a few features that this piece offers, however it seems if I have an amp with bass control already I can just buy a basic line out converter and go from there.
06M4.5
Car: 2006 M45
stepping it up, not down
it's better than a regular line out converter
kermit the guy
Car: 2008 infinity M35 Sport
my setup is a kicker 100 mono amp to an L7
400 to 4 kicker amp to JBL seperates
before i had an L5 and the bass wasnt hitting good enough because of the trunk and how good its sealed, but when i upgraded to the L7 and AMP ! now the sound is really clean and a little thumb without going over board !!!
PlatinumM35
Tein H-Tech Springs
Slotted/Cross Drilled Rotors
Wagner Ceramic Brakes
22x9 Status Wheels
Rear Entertainment Aftermarket
15'' RE Audio Subwoofer
Infinity Reference Door Speakers
I had that same problem kermit. I went with an RE Audio 15''. It can be a lot but blended well once dialed in.
cvillanFL
Car: 2008 Infiniti G37
2007 Infiniti M35 Sport
OP - Is your amp mounted upside down at the top of the trunk? If so, how did you mount it? Bolts? I heard it's not safe to mount amps upside down, any issues?
PlatinumM35
Tein H-Tech Springs
22x9 Status Wheels
@cvillanFL mounting an amp in that position is not recommended. When heat is dispersed from the amp it rises, so if the amp is upside down the amp won't cool properly. Most digital amps don't get as hot as other amp classes, so you may be able to get away with it. Just know it may shorten the lifespan of the amp. Hope this helps.
06M4.5
Car: 2006 M45
Yes my amp is up side down but it's not a problem as it's mounted (screwed) to the metal of the rear deck. The metal of the deck helps with the heat.
Audison amp can run all day at 1 oh but I have my set at 2 oh. You pay a little more for the Audison but you get a whole lot more. Best amps I have owned so far.
As for sound in to the car I always have the armrest down and not too long ago I got a 4" port that I will install on the deck when the weather gets warmer.
labby2312
Car: M35x 2006 Blue
Nice Freddie.
06M4.5
Car: 2006 M45
labby2312 wrote:Nice Freddie.
Thanks Labby
lets see some pics of that M slammed :biggrin:
cvillanFL
Is the trunk liner in between the amp and metal deck? I was thinking about doing the same thing. How'd you go about mounting it?
06M4.5 wrote:Yes my amp is up side down but it's not a problem as it's mounted (screwed) to the metal of the rear deck. The metal of the deck helps with the heat.
06M4.5
Car: 2006 M45
Liner has to be removed in order to sit the amp on metal deck, after amp is installed you need to trim the liner to expose the amp.
Not hard but it would be nice to have extra hands.
