Subwoofer Question
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
ex35tdt
Can you share how the aftermarket wired into the stock's wiring?
In the trunk there is a terminal out to plug into the stock woofer at the spare tire. Can I disconnect this and connect audio signal wire (+/-) and AMP signal to the aftermarket amp and sub?
OR
If I leave it as is and just tap or split the audio signal to the aftermarket one, I can have both stock and aftermarket sub on at same time?
G3LO
Car: EX35 Journey Package
I am not good with electronics. But from what I have seen he tapped into the speaker wire on the right panel between the front door and the rear door. The middle panel that splits the front and back door. I think he also used an RCA I believe its called.
Lastmboy
Car: 1997 Nissan Maxima SE
I'm jumping in way late on this, but just spotted this thread. I'm in the process of dealing on a 2010 Infinity EX and would like to do something just like this. I was also looking at JL Audio. I currently have a 1997 Nissan Maxima with a system in it that I really like... Kenwood DDX812 head unit, Hertz components powered by 1500w Kenwood Excelon Digital, Alpine center channel powered by Orion 300w, and two 10" Kenwood Excelon 1000w slim mounts powered by Kenwood Excelon 1200w class D mono. It's going to be hard to walk away from that system, but the car is getting too many miles on it, and my son wants it. I was trying to figure out a way to at least get something half decent in the Infinity EX. The "premium Bose" is nothing to write home about, but I figure it might not be so bad if it at least had some decent bass to go with it. My install guy figures he could wire in an amp and subwoofer at the back.
You have me intrigued with what you've done here. I figured I would need at least two 10" subs, which would suck up just about all of the space behind the rear seats. However, if just the single JL is as good as everyone says, maybe I don't need two. Do you think the 10W7 with the 500/1 amp would give me as much as my two Kenwood slim mounts? It sure leaves a lot more space back there. I'm definitely an SQ type of guy, although I do like some volume, and I tend to like a bass heavy mix. No rap. More funk and rock. How do you find the stock Bose system in the Infinity sounds with the JL sub to help it out?
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
