timderiksen wrote:sub sonic is around 27hz i dont listen to screw even tho im from the third coast
Technically, subsonic sound is sound that's so low, you can't hear it. Which has been said is <20hz for a while now.
timderiksen wrote:the xMax for the speakers is around 15hz
That doesn't make any sense. Xmax is a measure of distance, typically in millimeters. 15hz is a frequency.
It's almost like saying your car will do 0-60 in red...Makes absolutely no sense.
Just a heads-up, with a tuning of 36hz, anything below tuning will cause your subs to unload and could cause damage if you don't have a subsonic filter.
Hope that helps
