AmoebAssassin wrote:It's not that what we're saying doesn't pertain to his question, but rather that it seems as though he's ignoring our perfectly logical and spelled out arguments because he's got some hell-bent desire to not spend what, 75 bucks for a proven modification.
There's no need to re-invent the damned wheel if the wheel has been working this long, savvy?
Greg, this is a good plan for cars making good amounts of power.AZhitman wrote:AA - Based on your comments, I'm going to remove my subframe spacers completely and replace my bushings with something more appropriate as well.
I have THE MOTHER OF ALL WHEEL HOP going on in the 'vert, so maybe it's time for me to take my own advice.
Don't forget that you still have springs, struts and tires. I suggest you go with aluminum collar/inserts before your oem bushings go completely bad.Edub1 wrote:I'm envisioning an aluminum bushing making everything rock solid. Where does the cushioning effect come from?
I have spl's aluminum bushings and i knew there was going to be increased noise and vibration, but is clunking included in that noise?The rear of the car is alot more stiffer and feels more planted but there's a clunk when i shift in lower gears and sometimes when engaging the clutch is this normal?94_240sx wrote:If your oem bushings wear out, body and subframe will be disconnected eventually. If that's the case, aluminum bushings won't do any good. I know some people took them out cuz oem bushing were shot and aluminum bushings were making bad clunking noise. If your oem bushing are still in decent shape, you can get more soild feel and prevent old bushings going bad. Phase2 has them $75 per set. It's based off of Kazama. That's what I'm going to get. I know many other places sell aluminum bushings, but look like phase2 has a nice set at decent price. Besides, I'm not a big fan of red, blue and gold color bushings. I just want plain silver ones.
http://phase2motorsports.store....html
If your bushings are shot, this is what you have to go through. zerothread/97924
I've learned all these by reading other people's posts. Please feel free to correct me if I'm wrong. I don't want to give out wrong info to other people.
I have the Phase2 aluminum spacers (same as all the others), and there is some serious clunkage when i shift or sometimes when i turn corners. It's just the nature of the product.BHayes_S13Coupe wrote:The rear of the car is alot more stiffer and feels more planted but there's a clunk when i shift in lower gears and sometimes when engaging the clutch is this normal?
A "strength-equivalent" aluminum structure, having used deflection (stiffness) as the design criteria, will have been built using roughly 50% greater plate thickness. We might then say that this strength-equivalent "one and a half inch" thick aluminum plate will yield at around 51k per square inch of surface area (around 29% greater yield strength than the "equivalent" region of steel plate), and will fail at around 67.5k psi (around 12.5% greater ultimate strength than the "equivalent" region of steel plate).AmoebAssassin wrote:
No, you're as wrong as you can be. It is NOT a known fact that aluminum is stiffer than steel; thats just plain idiocy.
Here, if you don't believe me, here are the elastic moduli for aluminum and steel:
http://www.mse.cornell.edu/cou...s.htm
Steel Elastic Modulus: 200-207 GPaAluminum Elastic Modulus: 69 GPa
See? Steel is about three times more rigid than Aluminum.
Yokota, the collars still rely greatly on the stock bushings. The holes in the collars are not clearanced tightly around the subframe mounting studs, and by virtue of this cannot transfer any significant load from the subframe to the unibody. They work by compressing the stock bushing and stiffening it in this manner. Although they do work, they do not eliminate bushing slop completely, as your stock rubber bushing remains the main mode of force transfer between the subframe and chassis.
Sources please?240sx_megasquirt wrote:A "strength-equivalent" aluminum structure, having used deflection (stiffness) as the design criteria, will have been built using roughly 50% greater plate thickness. We might then say that this strength-equivalent "one and a half inch" thick aluminum plate will yield at around 51k per square inch of surface area (around 29% greater yield strength than the "equivalent" region of steel plate), and will fail at around 67.5k psi (around 12.5% greater ultimate strength than the "equivalent" region of steel plate).
Of course these broad generalizations are intended only as a way of illustrating the approximate relative strengths of the materials. However, from these considerations we can see that the aluminum vessel will have a greater overall strength than the steel vessel per square area of plate. The reason for this is that the aluminum plate will, for the sake of stiffness, be 150% the size of the steel plate.
