Those graphs only represent that exact driver in those exact boxes. Different drivers in the same box will perform different. The same driver in different boxes performs different (as you can see in the graphs). It's a package deal and you can manipulate your ported box to reach certain goals. If I used the same size box, but tuned it for 50hz instead of 18, there would be a HUGE spike upwards of 8-10db above the baseline of 0db.
schmiddr2 wrote:The middle graph, if I read it correctly, the sealed plays on into the sub 18hz frequencies at high excursion while the ported, being tuned for 18hz dies off. Advantage to the ported, better use of power and no need to produce le2s than 18hz IMO.
To me the last graph appears to show the sealed to be more steady. So when does a subwoofer become better suited as midrange woofer?
My ultimate question is: Assuming same sub, same power, and the 2 box options. Are there any differences in the sound being produced when they're played at the same hz? Or at any other hz?
The first graph is how much sound will be produced by the sub. As you can see, at 10hz (if the subwoofer did not run out of excursion) it would still play louder than the sealed because it's more efficient.
The second graph shows how far the sub's cone has to move in order to produce that level of sound. At 18hz, while the ported is producing ~10db MORE sound than the sealed, its moving less than half the distance. The graph just shows how the port effects the movement of the woofer.
Sealed is definately more steady and easier to manage, which is why people love them so much. They're so simple.
Something you mentioned was there's no need for sound reproduction below 18hz. In the home audio world, guys are trying to get large amount of output in the single digits. I, however, believe 15hz is plenty low and will also be the frequency I will choice to tune my enclosures to.
As for subs playing into the midrange, I don't advise it, but it's certainly possible for 15" drivers to play up to 2-3k (on axis) and cross it over to a tweeter. It's not common because it takes a hell of a driver to pull it off and creates another problem called "beaming" and can introduce something called intermodulation distortion at higher volumes.
