IanS »
https://forums.nicoclub.com/ians-u23642.html
Sun Feb 10, 2008 4:53 pm
If you are replacing the rotors, the best way to get them off is break them. Hit the rotor on the very edge as hard as you can. With a good sized hammer it should only take a few hits, when the rotor face breaks off the hat, it will cause the hat to crack loose from the hub, allowing you to slide it off with your hands. I have this problem at work all the time, it seems wrong to break things on purpose, but believe me, it works.
