deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Nov 15, 2005 2:37 pm
There is such a thing as a ka20de, domestic japan only.
You cannot build a realistic destroked rotating assembly using a ka24 as a base. Learn some more about rotating assembly theory and design and you will understand why. Ill give you hint, deck height.
A rotating assembly must be designed as whole, you cannot change a single variable and expect good results, its not all about piston speed. You must start from the ground up.
Edit: And btw, z24 is the ka24's primary ancestor, it is 89mm bore x 96mm stroke. The only differences in the crankshaft are the journals which are approximately .080" wider, and the larger diameter snout.
