Strange turbo noise
mval123
Car: 91' 240 hatch
Just got done with sr swap and for the first couple of days everything was going fine. Just today I started hearing this loud high pitched shriek coming from the turbo (stock T25) under boost,first I thought it was a leak coming from where the hot pipe meets the turbo, so I went back through and tightened everything down...same thing. There is no burning oil, the turbo seems to be boosting fine, no shaft play, blades aren't scraping. I'm running a greddy type-s bov (recirculating), is it possible it is leaking? The sound isn't a metallic shriek...more reminisent of a vacuum being pushed around the house and is just really loud...any ideas?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
fyi turbos make lots of cool whooshing noises, thats why everyone wants one, j/k get a boost leak tester. or your oil feed line might be pluged.
S13FASTBACKSR
Car: '92 Fastback SR powered
sounds like your turbo spooling under boost just like its supposed to
mkory
Car: Mazdaspeed Miata
I'm goint to bump this up...
My turbo when it builds boost occasionally makes a squealing noise... almost like a squeaky belt. Any ideas?
IanS
possibly oil starvation, what turbo do you have? Check your oil supply line
SlowS13Silvia
Car: '89 s13coupe built sr -sold- '97 s14 stock -sold- '91 z32 tt swaped!!
Mine does this every week until i tighten my damn exhaust bolts, the ones going from the manifold to the turbo. It also could be your gasket which happened to me with my paper gasket. Get a metal one it helps.
S13FASTBACKSR
the upgraded exhaust manifold studs are good to have from enjukuracing.com under sr20det turbo upgrades..they use an anti-vibration locking flanged nut so if that is the problem you wont have it nomore
DuckyD
Car: 1995 240SX
Also I thought I had a similar problem and took the car up to Enjuku. Come to find out, my upper-radiator-cooling-panel-metal-thing was vibrating against the rad support. We took it off and I didn't have any more squeeking or rattling.
ILikeMy240sx
Car: SR Power
When I had my T-25, it would squeal like a mofo as well. Turns out one of the nuts on the exh-turbo stud was loose causing ex gas to leak.
