jimbyjimb wrote:At the least they can order them. In a pinch it'd probably be fine to use autolite plats. they make really good plugs, at least as good as NGK. The only reason I didn't use 'em is because Nissan reccomends the NGK's and NAPA had the NGK's. No sense in testing the waters if you don't have to, but, given the option of 100 bucks for plugs or another brand I'd say screw it, as long as they werent Champion or Accel. A hundred bucks on plugs. Somebody should rape whoever determines that pricing.
I wish I didn't have to, but I had my tail in a crack. My Q was going in the shop early the next morning and I was having the chain guides replaced and valve covers resealed. Since they VC's were coming off, it was the consensus of the experienced board members that I did the plugs. I needed them and the stealership was my only option. I had called 3 different NAPA places and all they had was iridium.
5zigen wrote:That sure is on par with this one dumb teenager service counter rep that kept calling my car a "Q35" when I kept repeating "it's Q45"
What makes it worse is that the service counter rep was an old guy. 58-62 I'd reckon. Couldn't effing believe his lack of knowledge. I'm not very fond of my local dealership. If it's not a G or an M, they pretty much don't care.
