Alright, definitely don't do that to check for an exhaust leak. Go ahead and get yourself one of the leak test stethoscopes. it's a stethoscope with a metal rod on the end so you can stick it around all the flanges on your exhaust to hear for leaks. Also maybe the intake manifold as it shifts to boost instead of vacuum. I dunno man, just check for the leaks with that stethoscope thing, it's the easiest way to find them.SideWays=smiles wrote:my car does this when its not fully warmed up, my noise is an exhaust leak after the turbo, easyest way to check is to shove an old towel into the tailpipe the listen around the turbo and manifold for hissing or ticking, just dont rev it, it will just shoot the towel out.
why not, it works and it doesnt require finding a special tool, Im a mechanic and I know that using the right tool for the job is always a good idea, but most people dont have all the right tools and its not worth it to buy them just to use them once, so I often think of my days as a tinkering teenager with no money.spikNspan wrote:
Agreed and the test method will work fine. The stethoscope you referred to is mostly used to pinpoint bearing or tapping noises and would be almost pointless for an exhaust leak when the back pressure method is faster , easier and cheaper.SideWays=smiles wrote:
exactly, I used my scope today to decide if one of the injectors had failed on a guys sentra, it was running super rough, but all the injectors ohmed out within spec, so I busted out the scope and pressed it to each, # 3 was silent, problem solved. I use it all the time, but I have never used it to test for exhaust leaks.doridori23 wrote:
