Stock MAF limit = 350hp
Edub1
Car: 89 240sx KA-T
KATwo40 wrote:Hehe, sorry for the ol' switcheroo, there C-kwik. Didn't mean to do that to ya'.
So, would you agree that tuning for MBT would yeild higher hp seen on the stock MAF sensor?
It has nothing to do with it. See this equation, it is finite. They describe that HP and torque cross at 5252. It seems to follow that at 5252 RPM you are getting the absolute most power for a given volume of air.
horsepower = torque * rpm / 5252
Now you know exactly how horsepower and torque are related. There are no exceptions to this rule; they will always be related by this formula. In fact, it might be better to see them as just flip sides of the same coin. One result of this formula is that below 5252 rpm, torque will always be less than horsepower, at 5252 rpm they will be equal, and above 5252 rpm torque will be less. Note that a dyno never measures horsepower; it can only measure torque and then use the above formula to get horsepower.
Anyway, there are 3 ways to gain power: Increase flow, decrease resistance and increase compression. The question is whether they can take enough restriction off the motor and increase compression enough to make those numbers without increasing flow and burning more fuel. I don't think torque V. HP enters into it.
KATwo40
Car: 1993 240sx KA-T
Yeah, I understand that, Edub.
Imagine this for a moment...
Tune the maps for MBT. Now the torque value in the equation is higher than it would have been in just tuning for what most view as "safe."
According to the hp equation, more torque = more hp, period.
So, more thorough tuning on a steady-state dyno to optimize torque (which, by the way, is pretty much a direct reflection of the engine's VE) must yeild more hp, despite the airflow into the engine.
crzycav86
Car: 93 Nissan 240SX KAT
This thread is getting good. lotsa tek.
I just thought I'd add this part in regard to C-Kwik's tidbit on hp and torque. I want to talk about optimal shift points, and how we know mathematically which rpm is ideal for each gear using a dyno graph.
The wheel's torque is what produces acceleration. The factors for wheel torque is the torque output of the motor at a specific rpm and the gearing, which multiplies the motor's output to produce the wheel torque.(wheel torque = rpm @ specific rpm * gearing)
So if you want to maximize acceleration, you need to maximize wheel torque all the time.
You do this by revving the engine in the lower gear until the wheel torque in the next gear would be higher than if you kept revving in the lower gear.
This makes sense because the torque reduces as you approach the redline, but you stay in the lower gear(because it has a larger gear multiplier) anyways. If you shift at the optimal rpm, your gear multiplier is less, but your torque output of the motor is higher. The wheel torque in the higher gear would be greater than if you revved out way past redline(when your torque drops off substantially)
What you really need to take away from this post is that you shift when:
(torque @ a high rpm in lower gear)*(gear multiplier of lower gear) = (torque @ rpm in higher gear when shifted) * (gear multiplier of higher gear)
crzycav86
oh yeah... this whole torque/horsepower stuff started to really click after I read this article:
http://www.yawpower.com/tqvshp.html
KATwo40
^^^ I have my reservations about that article.
1. They describe torque as lb/ft (rotational force). Then, go on to say that it's more convenient to say ft/lb and continue referring to it in that way. In fact, ft/lb is a measure of force over time, which is totally different.
2. In the comparison between the Cummins diesel and the Honda F1 they state that if torque were the determining factor in winning races (in terms of acceleration) the Cummins would win.
They go on to explain that the Honda F1 would win because of having higher hp over the Cummins.
While this is true, it's not because the Honda had lower torque. It's because the Honda could rev much higher than the Cummins and sustain a broader torque band.
Remember HP = Tq * RPM / 5252.
The Cummins had a max RPM value of 3000, while the Honda had a max RPM value of 17,800.
This comparison is apples to oranges. A real comparison to depict the importance of torque in a race would be to compare two engines, both with X whp, but with varying torque bands.
For instance, take a Honda B series and a Chevy 350 sb. Let's rev them both to 6000rpm limits.
Give the honda a T3/T4 .50 trim with a boost threshold of 4800rpm.
Make the 350sb V8 an all-motor application.
The dyno would show the 350 making more torque in the lower rpm range than the B series engine.
The result? The V8 would have more useable power throughout the rpm band, resulting in better acceleration overall than the B series engine with equivalent HP and less overall torque.
The context of the statement, "Torque wins races, horsepower sells cars" is not to be read as, "Big peak torque numbers are better than big peak horsepower numbers." It should be read as, "Broad torque bands win races."
Edub1
Car: 89 240sx KA-T
KATwo40 wrote:Yeah, I understand that, Edub.
There is no question that proper tuning is going to give you more bang for the buck fuel wise. More specifically, more timing is going to do that. And that car used water (or whatever it was) injection to run heaps of it. They also might get away with leaner fuel conditions by using the injection. In fact, that stuff changes the equation so much, it is probably not even helpfull to compair it to a non injected motor. Super high octane is another timing booster.
Assuming most people will run pump gas, I don't think that car represents a good rule of thumb for determining how far to push that stock MAF no matter how good ones tune.
By the way, has anybody even managed a real good turbo tune yet? Everybody I'm aware of keeps running into the problem of going super rich. If you log into Hybridka under E tuning, you might see my post about TP. I'm beginning to wonder if TP isn't more a function of throttle position and less a function of MAF signal.
Say you are towing a heavy trailer and begin up a steep hill. You are at half throttle at 2500 RPMs, you floor it but your motor can not increase RPM due to the heavy load and steep hill. Now, your air flow hasn't changed much, just your throttle position. So does the ECU go to the right of the map or no?
KATwo40
Actually, the load increases, and consequently, so does the airflow. As a result, the map does read to the right as the throttle opens more. But, it's not because of the throttle position input. It's because, as the throttle opens, the engine can injest more air (which must pass through the MAF sensor first).
I have a good turbo tune on my DOHC. If you'd like to look at it, you're more than welcome. It's for Z32, 370's, T3/T04E. I drove the car to Indianapolis about a month ago and @ an avg. of 90mph, I got around 28mpg.
Not to mention, the on-boost power is very good. I'm seeing AFR's in the low 11:1 range (a little K adjustment would take care of that just fine). I'll fine tune it on the new engine in a couple weeks.
On another note, please Email me regarding your BTM setup. I need to run an idea past you to help you out with your tuning process.
[email protected]
crzycav86
Edub1 wrote:There is no question that proper tuning is going to give you more bang for the buck fuel wise. More specifically, more timing is going to do that. And that car used water (or whatever it was) injection to run heaps of it. They also might get away with leaner fuel conditions by using the injection. In fact, that stuff changes the equation so much, it is probably not even helpfull to compair it to a non injected motor. Super high octane is another timing booster.
tuning using throttle position for load can't be done on a turbo motor because airflow changes with throttle position(spool up time). So it's not very effective. You can do it with NA because air flow is relatively constant with throttle position and rpm, as long as you don't travel to areas with different climate conditions and temperature. tuning with mass air flow for load is convenient because it accounts for all of these things.
and yes, the mass air flow does change when you increase the throttle because you're reducing the restriction to the motor, allowing it to take in more air.
C-Kwik
crzycav86 wrote:oh yeah... this whole torque/horsepower stuff started to really click after I read this article:
That's a really good article.
C-Kwik
KATwo40 wrote:^^^ I have my reservations about that article.
1. Actually torque is referred to as ft-lbs or lb-ft. It does not use a "/". 1 HP or 33,000 ft-lbs/min is equal to 330 lbs lifted 100 feet in 1 minute. Or even 100 lbs lifted 330 feet in one minute.
2. It's not the broad torque band that matters. You're still looking at the entire graph as a whole. You have to look at each RPM point individually. HP is not a culmination of torque built up over the RPMs. If you make 200 ft-lbs of torque at 4000 RPM in any motor, it will always make 152 HP at 4000 RPM. It doesn't matter what the torque curves look like before or after 4000 RPM. As I said earllier, the HP is a moment in the RPM.
In your example of the turbo motor with a boost threshold of 4800 RPM, if you regeared the transmission to keep revs over 4800 RPM everytime tyou shifted, then it won't matter what the torque/HP curve looks like before 4800 RPM. If its not at those RPM's, it negates that part of the curve entirely.
I'll give you a better example. We'll use theoretical motors with perfectly flat torque curves.
Motor A has 100 ft-lbs of torque from 0 RPM to it's 10,000 RPM redline.
Motor B has 1,000 ft-lbs of torque but revs to only 1,000 RPM.
Motor C makes 50 ft-lbs of torque up to 5,000 RPM, but makes 100 ft-lbs of torque from 5,000 RPM until it's 10,000 RPM redline.
We'll assume Motor B is directly driving the wheels.
Motor A will have to be geared 10:1 to match motor B's performance. Essentially, Motor A would end up making 1,000 ft-lbs of torque though torque multiplication and have the same top speed in that gear. They would accelerate the same.
Motor C on the other hand, if geared 10:1, would accelerate with half the torque at the wheels of the other 2 motors up until 500 wheel RPM. After that the acceleration rate would be the same as the other 2 motors would after 500 wheel RPM. Motor C would be a good deal behind the other 2 cars as it accelerated slower until 500 RPM and it would never catch up.
Here's the key. Lets say these cars are designed for road racing. And give the track they run on, RPM's never fall below 600 RPM. Each car would be able to run the exact same time as acceleration would be equal among them as they all put an equal amount of torque to the ground. But if you were to drag race the cars from a stop, Motor C has to get through 5,000 Engine RPM or 500 Wheel RPM with half the torque of the other 2 cars before it begins to accelerate at the same rate. So it will have lost ground at the beginning of the race. It won't catch up, but after 500 RPM, it will nto lose anymore ground either since they are accelerating at the same rate.
Calculate and compare the HP level at redline for each motor. You'll find they are all the same rating. Yet Motor C is obviously at a disadvantage in certain situations. What my point is here is that The Torque and HP for that matter only apply to the RPM it occurs at. And if the motor never runs at a given RPM for the situation it's in. Real cars have many gears so the only time such a situation would be an issue is in 1st gear. After first gear, it would be expected that the transmission attached to the motor would keep the engine in the higher torque/HP range and would no longer matter hw much torque is available at low RPM's.
In the real world, engines have torque curves that rise to a peak and then fall again. These curves have different characteristics, but essentially all possess this trait. Typically trucks will have a lower peak, shifting the broad portions of the curve to lower RPM's, where as race/high performance motors will shift the peak higher up to better make use of the leverage provided by the transmissions mated to it.
HP is no more than a measure of how effectively the available torque can leverage the drivetrain through the RPM's. Looking at torque alone tells you little about how an engine performs. Without knowing what RPM the torque occurs at, you can't determine how effectively you can use the torque. Torque without RPM's is 0 HP. Torque with more RPM's results in greater HP. A given amount of torque at higher RPM will always be able to put more torque at the wheels than the same amount of torque at a lower RPM. Lower levels of torque at higher RPM, depending on the actual torque figure and RPM difference can make more HP than it does at the torque peak. In fact, Peak HP in just about every motor occurs after the torque peak.
Lets take an 04 350Z for example. 287HP at 6200 RPM and 274 ft-lbs at 4800 RPM. This is 243 ft-lbs at 6200 RPM and 250 HP at 4800 RPM.
Let's gear this so that the wheel RPM is 500 RPM at the peak HP and the peak Tq.
For peak HP, the gear ratio would have to be 12.4:1. For Peak torque, the gear ratio would have to be 9.6:1.
At 500 Wheel RPM, the Wheel torque at peak engine torque RPM would be 2630 ft-lbs(9.6 x 274).
At 500 Wheel RPM, the wheel torque at Peak engine HP RPM would be 3013 ft-lbs(12.4 x 243).
The wheel torque at 500 Wheel RPM is higher at the peak HP than at Peak torque. This will work at any wheel RPM you choose and calculate more. You can also make these comparisons between different motors as well.
In reality, the torque/HP curve does have an affect on overall acceleration, but only from a standpoint of putting down more torque to the wheels over a wide range of RPM's. This is actually more of an issue because we have set gear ratios and to make better use of a transmission's gearing, we need to have reasonably broad power curves. But if you have a CVT transmission, you would put down the most torque at the wheels by keeping the motor running at peak HP and having the CVT constantly change the ratio to accelerate the car while maintaing the peak HP RPM. In theory, buy doing this, you would only need to make power at the peak HP.
Sorry if this is long and maybe a bit convoluted. I was typing this out at work between calls and other distractions. I'll clarify later if need be.
scarboroughdub
whoaa whoaa what happened to the original issue,
currently im running a stock maf on a blow through setup and im maxing the maf at around 280whp.
i am able to make more power but i have to do alot of trickery in the VE table.
Edub1
Car: 89 240sx KA-T
By how much did you increase your TP scale?
Seems like you could bump up your last fuel column to compensate. An ugly way to tune but...
nissanfanatic
Car: 1992 Nissan 240sx SE
C-Kwik wrote:Just an FYI, Don's set-up is pretty comprehensive. I can't comment on the MAF voltage as I can only rely on testing done by others. But as far the power he's reaching, his set-up may allow him to run slightly leaner to bump up power and make better use of the fuel flow capacity. He retained a 9.5:1 compression, is running a race head, turbo cams, water injector, and intercooler sprayer. I've known Don for a while and his attention to detail is top notch. I'm not surprised he's making such great power for 12.5 PSI.
http://www.pdm-racing.com/features/240sx2.html
I did 326whp on 12psi with an unopened engine...
