C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Nov 17, 2006 2:28 pm
It factors in time, yes, but the figure is still momentary. And HP is a representative number that describes what work a particular force will do over a period of time. More specifically, 1 HP = 33,000 Foot-Pounds per minute. This is equivalent to moving a 330 lb weight 100 feet in one minute. But if you were to move the same weight 50 feet in 30 seconds you still get the same HP. 25 feet in 15 seconds is still 1 HP. No matter how many times you cut this down it will still be 1 HP. So, for that moment in time (as time approaches 0), it will still be producing 1 HP. HP is representative of the work it would do, but HP in a motor changes with RPM.
Actually HP doesn't mean much without a transmission. At least in terms of cars. The acceleration of a car in a given gear will be directly related to the torque curve. Where torque is highest, the forward accelerative G-force will be highest. If all cars only had one gear ratio, Torque would be the only number that matters.
Consider for a moment, a motor that produces 100 ft/lbs of torque at all RPM's. Lets say this motor spins to 10,000 RPM It's not going to make any more torque at 10,000 RPM than at 1,000 RPM. Yet the motor will be making 10 times more HP at 10,000 RPM than at 1,000 RPM(19 HP vs 190 HP). In a given gear the acceleration rate will be the same(ignoring frictional losses). But what happens when apply 190 HP at 1000 final RPM. You gear down the speed by 10:1. The result is now 1,000 ft-lbs of torque at 1,000 RPM. You're now getting 10 times more force at the same speed. As you can see, the HP and torque are both 10 times more at 10,000 RPM than at 1,000 RPM. This tends to be hard for many to grasp as HP and Torque Peaks tend to occur at different RPM's, and manufacturer's don't publish the HP figure at torque peak and Torque at the HP peak. People tend to believe they are two different things. They are simply a different way of looking at the same thing. Scientifically, they represent different things, but for all intensive purposes, neither is more important than the other as long as you are looking at a dyno and can see the entire scope of the curves involved. If I were to choose one to look at when determineing how powerful a car truly is, I'd look at HP as it factors in RPM already.
