I knew that response was coming...
Yes--someone did say that forged internals were crap and that you should run stockers. I disagreed with that idea. "id take that detuned car anyday...."me too--im just saying that it wouldnt hit the street with over 400 to the wheels. A 4th gear dyno pull is very different than ripping thourgh all 5 gears. The car reacts differently to the different loads it will see in each gear, revs are fast in the lower gears etc...dyno numbers dont determine how reliable a ka will be. However, ther are plenty of built ka's that run around with 400--and they are plenty streetable AND reliable. Klatter for one...rick--pornfalkes (sold) etc etc. Ill hopefully have the built motor done within the next month or two. 9.0:1 or 9.5:1. And yes--i hope for it to be nasty. Alky injection, nitrous, the works.White bunny may run around with it. I dont know him at all. BUT--cars that run with 1 bar on the street all the time are more the exception than the rule. Its not common to do, and if you do, most dont pull it off. YET. Thats why i think this is a great post. Theres no arguing that what ivan did was awesome, but i believe in something that is a little more stable and willing to stand up to abuse than KA stock internals. When these power nimbers become commonplace, then itll be the norm, but for now, all ive seen the norm as is people run power like that, and alot of times the motor doesnt last."this sounds like a nother one of those 'the kas wasnt meant to be turbocharged' statements..."Umm--it wasnt. If it was, It would have been turbocharged from the factory. The cams would be designed with boost in mind, and the ecu would behave differently in regards to maf readings and etc..The kas wasnt meant to be turbocharged. But even so--that doesnt mean that when it is turbocharged, that its not a VERY capable motor. I like the ka for its torque. I like it because it came in my car, i can work on it, find replacement parts with ease..etc. The guy i was referring to was dennis. His car was run with no exhuast and race gas on 15 psi with a granatelli maf (blow through) so his car is not exactly the "norm" in regards to the typical street driven 240 either...and no, he doesnt run around at that power level. I do like his car though
ill skip over one point for a sec---600 whp can be totally streetable. hell, if 544 is, then why not 600? Ball bearing, built motor, and maybe some gas. Sounds plenty streetable to me. You dont have to be running with 600whp all the time. a 600hp car riding at 350 on the street would be perfectly fine with me..
and the last point--if you dont try to make people think the way you do, then why analyze my post with no intention other than to basically ARGUE with every point i made? It served no educational merit, yet you went on just typing away anyway.I dont appreciate having my posts broken down, analyzed disagreed with at every statement by a mod who, as I can see, spends more time on this forum than with his hands on a motor. I work on my ka plenty, how about you? Mine is coming along nicely, hows yours? Mine runs great and handles like a dream...yours? My point is, I believe I have a really good idea as to what im talking about because i WORK on 240's enough to. AS far as i can tell, you dont. Reading compressor maps looking at dyno charts and knowing everyone elses ride from top to bottom doesnt make you an expert. Thanks for taking the time to respond with pointless, hardly justifiable arguements. It makes this site lots of fun to visit.
