Stock Boost?
300bucks
Car: 1988 Conquest Ls1 powered
I was reading on here a few days ago about how much boost the stock SR makes, and a few posted 7.5, and some said 10psi. Mines making 7.5, and I want 10. If anyone knows the link to the post, or what is missing from my set up to run 10 stock, please let me know. Thanks
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Technically with the SR there is no such thing as stock boost. They either overboost (Most common) to around 10 psi or underboost to around five. If you aren't boosting 10 or don't know the obvious way to get there is a boost controller.
90SRpwrd240
Car: 1990 240sx SR20DET
300bucks wrote:I was reading on here a few days ago about how much boost the stock SR makes, and a few posted 7.5, and some said 10psi. Mines making 7.5, and I want 10. If anyone knows the link to the post, or what is missing from my set up to run 10 stock, please let me know. Thanks
Yeah, stock is about 7lbs...to get anything higher than that you need a boost controler (basically a valve that allows for more vacuum) Look on ebay they are all over.....On the stock SR, I wouldn't go anything higher than 14lbs.
90SRpwrd240
yep he beat me to it
300bucks
will do very soon. Thanks for the replys
redtop91
No problem. Just make sure to save yourself a headache and get a manual boost controller.
90SRpwrd240
redtop91 wrote:No problem. Just make sure to save yourself a headache and get a manual boost controller.
Agreed....although my friend just put an electronic one in his SR and he loves it...i think GReddy but not positive...but yeah I've also heard alot of bad things about them, I'll stay manual
otterman
weak, I'd never go to manual after I've had my electronic. It's not hard to set at all
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
you have to make sure you have the setup for the boost also, you dont want more than stock with out a new fuel pump, and the stock sidemount heatsoaks super easy at about 9 or 10 psi.
