LegendRacer wrote:addidas...are u saying...ur sideskirts are held on by and only doublesided tape?
if the bottom has no clipping and only tape, then if u hit a bump high enough, wouldnt it rip off easily?
There are 2 screws on the ends and double sided tape in the middle. I have bottomed out the rockers before, they hold up fine.
alphapig wrote:I'll take your word for it since you've had them longest haha
Would you recommend a shop putting them on for me then? I had no problem installing the fascia, but maybe a shop would do a better job of using the tape?
Plus I can blame them if it ends up looking wrong?
Input?
They should come with the tape pre-attached to the rockers, its really easy to do. I did it with no instructions, and I had to attach the tape to the rockers and car correctly. Worked out fine. Do it yourself, if you mess up, you can always take to to a shop and go with your original plan
Scandinavian Flick wrote:i would have to rivet them on, i couldnt trust the tape,
Good luck riveting polyurethane. Do it the way instructed
