ruiznestor »
https://forums.nicoclub.com/ruiznestor-u35322.html
Mon Aug 07, 2006 9:04 am
I had sort of the same problem, EVAP, Purge, O2 Sensor IAAVC or whatever, and some other things were off line and the car would not idle, the check engine light would come on even after reset, I grabbed a multimeter and the wiring diagram, mine's a 96, and found out that all of these sensors were under the same circuit and that a positive wire was grounding, so i pulled the engine harness out and re insulated it and that fixed the problem.
