A bad ECU will just not let the car start period. It will not flood the engine.LYDS wrote: Is it possible a bad computer can be causing this to happen?
That's not entirely true; If an injector circuit (or multiple injector circuits) are shorted, they could stick open. Also, if the ECU is getting bad readings from the ECT, MAF, O2, IAT, or other sensors it could be running the engine way rich. I would backprobe the ECU terminals to verify the readings at the sensors are the same at the ECU...maxnix wrote:A bad ECU will just not let the car start period. It will not flood the engine.LYDS wrote: Is it possible a bad computer can be causing this to happen?
LYDS wrote:Is it possible a bad computer can be causing this to happen?
If it could indeed short to power the injector open (never has been reported), the current draw would be most notable and would probably melt the injector coil in a few minutes.Lokim wrote:That's not entirely true; If an injector circuit (or multiple injector circuits) are shorted, they could stick open.
You seem to fail to understand that there is a leak! No "if" about it!LYDS wrote: What else can be the failure in the fuel rails if there is no leak?
Please describe the "testing" method.LYDS wrote:that has been checked and tested several times already both the lower o rings and injectors
