jj702s1 »
https://forums.nicoclub.com/jj702s1-u136194.html
Sat Apr 02, 2011 5:23 pm
I had that similar problem as well. First the car would start then die out and would not start back up unless I pressed the gas pedal to the floor, resulting in a big cloud of white-ish smoke, then it would run fine. That told me that there was still fuel left in the combustion chamber. Pressing the gas pedal to the floor on fuel injected cars while truning over usually stops the injectors from spraying more fuel so the left over fuel inside the cylinder could burn off while attempting to start. Well now it was time to trouble shoot why. I did all the common tests, as instructed from this website. MAF, test the ohms on the injectors, fuel pressure, vacuum pressure. And it wasn't until I did the vacuum pressure test from the vacuum hose off the fuel regulator where I found my problem. I had good vacuum pressure but there was fuel in the vacuum hose, which led me to believe that the diaphram in the regulator was bad resulting in fuel being sucked into my intake manifold. Went to the junkyard and picked one up for 6 bucks. And that fixed my problem. No more starting issues and no cloud of smoke, hence no more flooding. So don't rule that out also. Just thought I'd share my experience with you and I hope you figure it out. There is a lot of information on this website and there is a good chance someone has had the same or similar problem with a solution, so good luck.
