Post by MajorRoach s13 » https://forums.nicoclub.com/majorroach-s13-u86464.html Mon Jan 21, 2008 1:04 pm
Post by x240xdrifter » https://forums.nicoclub.com/x240xdrifter-u22577.html Mon Jan 21, 2008 2:48 pm
Post by IanS » https://forums.nicoclub.com/ians-u23642.html Mon Jan 21, 2008 5:44 pm
This is a good start, but if that does not fix the problem, I would start checking the cable. Are you sure its the throttle plate? Most of the time when I get sticky throttles at work, it is a kink in the the throttle cable that causes the problem.x240xdrifter wrote:spray in TB cleaner and/or starter fluid into your throttle body. There probably is excessive build up of carbon around the throttle plate
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
