gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Thu Nov 06, 2008 7:26 am
interesting. I had an ignition issue for a while last season, so i feel your pain. Here's how it went, dunno how applicable it is to you:
ran Iridium 7s at .8mm on stock coils. ran great for a bit, then breakup started happening. breakup was super consistent. basically at an exact rpm it would start stuttering.
dropped coin and got splitfires and put them in. did not change the plugs on purpose just to see what would happen. still had breakup, but the sound was very different. the miss didnt sound "as bad" if there is such a thing.
went to copper 7s gapped down to .021" or .53mm. hasnt missed a beat since with these plugs and the splitfires. my old coils are still sitting on a shelf. i really should put them back on just for kicks to see if the splitfires really are doing their job. i'm thinking they arent anything special over OEM, but at least they cheaper than new OEM, and not 15 years old.
i say give the copper 7s another shot with a new set, gapped to around .5mm. if you get the same exact thing it might be time to look into the coils unfortunately. they're probably just too old.
also would like to add that my old coils really looked perfectly fine. all the connectors were good, those little springs had no corrosion, etc. boots looked fine and sealed tight. only thing i did notice was the black paint around the coil (where it bolts down to the aluminum brackets) was starting to chip off on certain coils.
