If you used one of those 30 day warranty, $15 ignition switch replacements, it has likely reached the end of it's expected life. Something more reliable like Beck/Arnley or the original Infiniti/Nissan brand 48750-0M010 is advisable for this simple but critical part.
Those security screws seldom get any corrosion, Md. Usually you can use a sharp punch and a hammer to get them to budge, then they come out with fingers. I'd have a drill and an easy-out handy just in case, but it's very rarely necessary.
I could not recall when the last time my steering wheel lock was engaged so I was curious if I could fix it if it was not working. Just checked and it is working but I think it might be possible to fix if it is just a gunched up spring pin not popping out when it should. This image below shows this pin that pops out when the key if off and the wheel is turned slightly to the right. The pin retracts when the key is turned. If there is dirt and grime in and around where the pin slides in and out with spring tension it has, it might be possible to free up the sticky pin by cleaning the sliding action with alcohol or an electrical contact spray cleaner. Maybe just a shot of silicone spray lubricant would do the trick. You would still have to remove the lock-set but it's worth doing if it's worth it to you, so you can fix it instead of replacing it.
Could you explain this a bit? Is this an easy do or not? And what does Md mean here?VStar650CL wrote: ↑Fri Aug 22, 2025 10:06 amThose security screws seldom get any corrosion, Md. Usually you can use a sharp punch and a hammer to get them to budge, then they come out with fingers. I'd have a drill and an easy-out handy just in case, but it's very rarely necessary.
Fantastic photos again. Have you done this repair. I think I remember you writing that you were only considering do the repair.mdmellott wrote: ↑Thu Sep 04, 2025 10:50 pmThe steering wheel does not need to me removed. Getting those shear-head head screws out will be the only challenge. The hex-head of those bolts will be broken off. Replacement bolts from a Nissan/Infiniti dealer (48703-06F00) or aftermarket from Amazon will be needed. There won't be any issues of anything electrically getting out of sync by removing the lock cylinder. Beck/Arnley had a good reputation for as long as I can remember, as did the Bosch brand of components, but too many past reputable brands have lost their quality control when they started sourcing their parts from China. You would be better off buying an original Nissan/Infiniti switch.
Md = @mdmellott.dk203040 wrote: ↑Thu Sep 04, 2025 11:01 pmVStar650CL wrote: ↑Fri Aug 22, 2025 10:06 amThose security screws seldom get any corrosion, Md. Usually you can use a sharp punch and a hammer to get them to budge, then they come out with fingers. I'd have a drill and an easy-out handy just in case, but it's very rarely necessary.
A picture is worth 1,000 words !!!mdmellott wrote: ↑Fri Sep 05, 2025 7:25 amI have not done this repair before but I know I could if I had to. There is no screw-head left on the currently installed screws so they need to be removed by an alternative means. The drilling and screw extractor method can be difficult. I like the punch method VStar mentioned. You need a small center punch to strike the outer perimeter face of the screw with a glancing blow to attempt rotating the screw enough to loosen it.
Good to know. Thank you for taking the time and providing the details.VStar650CL wrote: ↑Fri Sep 05, 2025 11:59 amMd = @mdmellott.
He just explained using the punch and hammer, so I won't re-explain it. The only thing I'll add is that it needs to be sharp, stuff like a carpenters' finishing nail punch won't work well.
