brndck wrote:the steering wheel locking mechanism is on the column. its entirely mechanical, not electrical at all. there is a small spring loaded pin on the top of the column, near the lock cylinder, that when the key is taken out, and the wheel is turned just right, will pop into a slot and "lock". on my old s13 it locked on me a few times while i was driving (fortunately while just pulling out of the driveway), so i removed it.
What year is your car? Mine has never locked except one time when the switch was out ffor inspection and i could turn the key 360 degrees.Would you have to take steering wheel off to access it?
BTW, it is useless as theft prevention as you just have to give it a hard twist to break or bend the pin. If yours is broken it suggest someone tried to steel your car or you yourself broke it.
