s14kaibigan »
https://forums.nicoclub.com/s14kaibigan-u6080.html
Wed Mar 26, 2003 9:07 am
I agree with the balancing...balance your tires first. While the car's in the air, ask the tech to check out the tie rods and ball joints...also check out the bushings. Under severe circumstances would the alignment cause a shimmy in the wheel. Also before you head to the shop, visually check your tires for any bulges in the tread or sidewall. Run your hand across the tread the way the tire rolls down the road and then the other way. It should feel smooth and flat both ways. If not, that may be the start of your probs.
