Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Wed Mar 26, 2003 9:07 am
First thing, if the wheel is bent, even if it gets balanced, it will cause the wheel to shake. If you see excessive weights scattered on different locations of the wheel chances are it's bent. You can also have a bad tire (or bad tires). Next, I'd check out the T/C rod bushings...scrap that. If they're stock, they need to be replaced. Adjustable arms are best, but a poly bushing will do the trick. Note thought that poly t/c rod bushings have been known to break lower control arms in half....I'd definately look into an adjustable set w/ heim joints (like spl, battle version, ebay, whatever..). Also, all your ball joints and LCA bushings should be replaced as well. Lastly, if your struts are blown (if they are stock, they probably are), they can also cause vibration.
Good luck!
