jamesblonde82 »
https://forums.nicoclub.com/jamesblonde82-u38650.html
Mon Apr 16, 2007 11:08 am
ok so i took off my steering wheel. step 5 was actually easy because my grandad had a steering wheel puller. i thought it was harded to line it back up with the marks to put it back on.... anyway the three rings where worn a little, but nothing that would affect it so much to make it not work. i cleaned it nonetheless and made sure the pins retracted back and forth well and put the steering wheel back on. took it for a test drive and still no cruise. but the grinding noise is gone when i turn, so whatever. the cruise on/off button located under the headlight up/down button on the dash will light up saying cruise is on, but cruise will not set and light in dash of course won't come on either. i've looked for fuses, but can't find one. also another symptom for awhile was the cruse light on the dash would actually flash sometimes when i was trying to set it. so i would turn cruise off, then back on, then try and set it again and it would work. was doing that all the way up till it stopped working altogether. another thing i noticed since i had the car was that it was slow to respond to inclines and declines, but i didn't ever think much of that. i wonder if it could be a sensor problem, or computer problem. i ruled out the connection theory. i just don't want to bring it to nissan and have them tell me it's all kinds of stuff i know it's not and get overcharged.
