Power steering problem seems quite likely. When I picked up the car, it was about 20deg. C weather and I still experienced it. That being said, it has seemed to get worse as the weather got colder.kamiguy wrote:Spoke to my dealer today and he mentioned that with the onset of cooler weather here in this part of Canada, and elsewhere too, obviously, there have been a number of calls about this matter. They say it's in the power steering cooling system. There is a fix in the works and at first it was thought it was in the power steering housing but that was not the case. He explained it as similar to a water hammer in your water pipes at home. Are the warm weather dwellers getting this vibration too?
Just brought my car in for the same issue and got exactly the same response. They also mentioned that a tsb or notification was released.KJ911TT wrote:My dealer thinks the sound is coming from the power steering rack. They called "Techline" and ordered a new rack.
It is on back order, but when it comes in, they will replace it for me.
If that fixes it, they said that they may issue a TSB.
- KJ
I took the tech for a ride and reproduced it multiple times for him. The first the it happened, he acknowledged it right away and then Infiniti fixed it.yellowsun75 wrote:I just had my very first maintenance service at the dealer that I purchased my EX35 AWD from.
I also had the same vibration problem when I turn to right at low speed, and after reading all the helpful information on this forum, I mentioned it to the service rep and asked him to see if it really is due to PS rack and pinion assy.
.....well, hours later, I got a call from him saying he could not reproduce the noice, but had talked to techline. He said this issue is already known within techline, but no repair instruction or suggestion has been officially made; therefore, they CANNOT fix it for me!!!
They asked me to periodically contact them to see if the repair instruction has been issued officially!!!
What? That means I just need to live with this strong noise until further notice?? They said since it's not an official replacement notice, they cannot simply change the PS rack and pinion assy like others did!!!
AHHHHHHHH!!!!!
Glad to hear your progress on this KJ.So is the steering feel heavier now that they fixed the vibration?KJ911TT wrote:The dealer lent me another EX35 but the loaner does NOT have the same steering vibration and the steering wheel feels noticeably heavier as well (I found my EX's steering to be REALLY light compared to every other car I've owned).
I think the light steering and steering vibration are related.
- KJ
Well, although I didn't get the chance to reproduce, they already acknowledged that TechLine is aware of this problem. However, they're still working on the solutions, and unless they provide the official repair instruction, my dealer won't fix it!!!KJ911TT wrote:
Maybe you need to offer them a ride with you and get them to admit it while it's happening so they can't turn a blind eye?
- KJ
Yes, the steering feels heavier, but still not as heavy as the loaner EX I had!EX35_bernard wrote:
