Looks like it was the starter. I was able to jump the starter using a remote start switch and it would crank, however, it would NOT using its own solenoid which makes no sense what-so-ever, but this entire mess as been a shh-ton of "coincidences".
When this started a month ago, having just the LOCK light lit on the START button the dash, and nothing would work except the remote could unlock the doors, everyone online said "Thats the Electronic Steering Lock Module" and when I removed the module, drilled out the security bolts, reset the plunger on it, and re-installed it, the car ran great for 2 more weeks , no issues.
When its started to do the same thing again, and I hit that module with a hammer, and the car started right back up after hitting it, that also was "coincidental" that it started. Now, these last few times, the dash would light, but not start, so that was a newer issue. I guess its possible the starter and the ESLM all burned out at the same time. The battery also had to be replaced about 2 months ago.
This entire time I said to myself, well its got to be that or the IPDM because "whats left", surely a OEM rebuilt Hitachi starter from Rockauto lasts longer than 20k miles.
Nope, don't go spend the money $220 for that starter as I got a whopping 20k miles, 1.5 years out of it before it failed again.
So I installed the cheap $86 new Chinese starter from Amazon and it works perfect. Car starts everytime now, well I have only tested it twice while its still on the lift. I have a Ranger Quicklift in my garage since I do all my own work.
Thanks allot guys for the help. Its been a journey. That car in the past 4 months has needed all these parts and a new water pump, pulleys, belt, its been a real show alright. According to Rockauto I have spent $2000 in parts in the past 4 months and these are all repairs, not upgrades. Water pump alone was $800 with all the gaskets and replacement pulley kit.
Oh, also, this is important, this Steering Lock Module hack does in fact work with or without the 10amp motor fuse in. Its on my car right now and its running because I tore that electronic lock module up by removing all the gears in it and taping down the buttons.
https://www.uhs-hardware.com/products/2 ... g-and-play
- infinitilockemulatore.JPG (42.25 KiB) Viewed 2479 times
Thanks again.
