FlatBlackIan wrote:It is possible to create your own steel braided lines using random parts, but its not really worth the trouble. Finding an inlet oil restrictor that is the correct size will be very difficult, if you dont get it right you will either be blowing all sorts of oil smoke out the exhaust, or you will starve the bearings, destroying the turbo. Just buy some lines.
+1
I have a new set of stainless lines complete that I can sell you. I have put together lines before, but after spending 50-75 bucks you will wish you just order them instead of nickel and dimming through little connectors and fittings. I used Earls connectors and paid between 7 and 11 bucks for about 6 or 7 fittings. the line was cheap but making it work right is what takes the time.
