cjb1989 »
https://forums.nicoclub.com/cjb1989-u259368.html
Fri Dec 11, 2015 5:59 pm
Hello everyone,
I recently purchased a 2001 Pathfinder SE 4x4 at a good price. The issue I'm having is it will start up immediately, and immediately die unless i give it gas right away for a few seconds and then it will idle and run all day. The colder the engine the longer I have to feed it fuel, and if it has been running for a while I can turn it off and restart without having to give it gas. The codes thrown previously have been for the swirl control valve solenoid and vacuum cut valve, as well as the typical downstream o2 sensor fail. Just wondering if anyone has had a similar issue or what the most likely issue is? I don't know much about the parts the codes are referring to so not sure if one is the likely culprit.
