ca18detgabby »
https://forums.nicoclub.com/ca18detgabby-u56657.html
Mon Mar 08, 2010 7:05 pm
Ive read all your previous posts. if you think you know better than everyone else trying to help, that is fine....... gl to you.
Ive only been around 3+ years now(not like ryan, dee, tim, ect), and in my short time.... timing is 98% of the issues.
the other 2 percent:
bad MAFS- wiring or the sensor itselfbad CTSstupid 1/2 as builds(surrounding poor wiring and/or ghetto rigging)
at least with my S13, I had to take apart several components to change the timing belt.......... maybe this isnt the case for you idk. If it is, it is very possibly you forgot to hook one little thing up(it happens).
If you had issues before, but it would start up, there are a number of threads on how to sort out pig richness. that also means that ONLY ONE THING HAS CHANGED! can you guess what that is, and why people keep echoing the same reason you are having issues?
Failed ignition=fuel sprayed w/o igniting= wet plugs...... pretty simple
