fabio240 wrote:what maf are you using and what is your afc set to?
I hate to say this, but I can't tell you how many times I've heard ppl say that the car ran fine before they changed the timing belt and insist over and over again that the timing belt was fine, but it wasn't.ca18detgabby wrote:...I would trip check your timing, timing is 98% of the issues around here...
.float_6969 wrote:I hate to say this, but I can't tell you how many times I've heard ppl say that the car ran fine before they changed the timing belt and insist over and over again that the timing belt was fine, but it wasn't.
Set the motor at TDC w/the upper timing belt cover removed and the dots on the cams lined up with the marks on the back cover. Take GOOD pics of the crank pulley lined up with the TDC mark, the intake cam dot lined up with the backing plate mark, and the exhaust cam dot lined up with the backing plate mark.
Until I see that, and am convinced all is Kosher, I don't have much more advice for you.
reason i started fixing the timing belt was because the car wouldnt strt up. breaking it down ...sjbsuperman1425 wrote:my thought is if it ran before, and now it doesn't, you did something in the process. Go through what you did and look at everything VERY carefully. You might be missing something. this is probably a really dumb problem with an easy solution..happens to me all the time.
sjbsuperman1425 wrote:your dropping resistor should have some resistance between the power inlet to each of the other wires i believe.
i tried searching the FSM but i couldn't seem to find any testing of the droppping resistor in it or even see it being mentioned.
