Update:
Got the boost gauge working.... crappy *** nylon line crimped at the firewall. I have 21 mmHG at idle and it will boost hard to about 7, seen it hit 10 once, and then fall on its face.
Tried to check the timing.... but the timing light I bought was a peice of ****. So gotta recheck it.
Also..... on a test drive, I blew one of the intercooler pipes off, so just to make sure that the IC isn't leaking, I just turned the hot pipe into the charge pipe to bypass the IC all together. So it goes directly from the turbo to the intake manifold. It held the idle a bit more steady and a bit more smooth, but no real change in the acceleration, still dies at about 4500. But when I was doing it that way, the car sounded like a little kid screaming at the top of his lungs when boosting. So I just turned it off and called it a night.
I am going to install the fuel pump tomorrow, then also check the TPS.
I am REALLY starting to suspect that it is in the wastegate myself. I will boost to 7 pounds, peak, and fall off. It won't hold the boost.
I'll let ya guys know what I can find out. But I am slowly starting to find out what is good on it, and what is bad.
Now that I just read that post about the bearings, I am getting kinda nervous about that now.....
Joe
BTW.... VDO boost gauges... very nice looking peice.
