Depends on what you call major. In relation to an SR swap, yes, it will require custom ****.[email protected] wrote:1. can an RB26DETT can fit into a 93 240SX without just major custom ****?
I don't think it matters but if you are springing for an RB26, might as well get the R34.[email protected] wrote:2. which version of the RB26DETT should i buy...R32, R33, R34 or does it matter?
Unless you want to pay Full-Race for an AWD conversion, then yes, you must use the GT-S transmission. The reason it is 800 bucks cheaper is because you cannot use it (in most cases) and most people discard it.[email protected] wrote:3. I guess the last question is, do i absolutely have to get the RB25DET GT-S transmission because jazzproparts has an RB26DETT GT-R motor with an RB25DET GT-s transmission for 4200.00 or can i use the AWD RB26DETT transmission which for some reason is 800.00 dollars cheaper together?
[email protected] wrote:I probably suck at searching too
Bronze MFP in the sticky wrote:also the stock tach can work, but you have to take apart the cluster and adjust the potentiometer on the back of the tach. you also need an aftermarket tach or something that reads correctly to calibrate your stock tach to.custom thottle cable is requred, but easy to make from parts from a northern hydraulic store or someplace similar.
lucky7 also in the sticky wrote:tach recalibration?http://lsauto.com/products.asp
i sent mine in to them. ill let people know how it turns out when it fires up.
Granted, these are probably for DOHC speedos only but you have a 1993 so the info should apply. Time to go back to SR. I don't even know what I'm doing here.Kansei240sx, you guessed it, sticky wrote:Tach Recalibration.
1. Pull Cluster2. Remove Backin and Clear plastic cover for the gauge.3. Take a sharpie and mark where the needle sits on the gauge face so when you're pulling the needles off you'll know where it sits so its not screwed up when you put them back on, you can also mark the spot it sits on. 4. Remove the gauge faces.5. Where the tachometer face is... there is a variable resistor that you can stick a screwdriver in. 6. Ussually you turn it all the way to the left.7. Once you've done that, do this entire process in reverse order.
Now since all motors are a little different and so are the electrical outputs, you might have to pull it back out, an then turn it a litte more right and a little more right, to get it perfect. Just keep doing it untill you're satisfied or if you have an SAFC it makes it alot easier to calibrate.
When using the sharpie on your gauge cluster, to get the stuff off, all you need it some axe body spray, or some red zone body spray. Apply it to some cloth and dab it onto the area that the sharpie has been applied to and it will either slowly or pretty much instantly come off.
If i left out anything or you're still confused quote and reply to this.
