starting problem...
nismoboy54
Car: 1991 nissan 240sx
wonder if anybody can help me with this....i just did sr20det swap on my 91 240sx..it was automatic now that i converted it to manual it wouldn't start, it don't even turn over....am i missing something?? do i have to mess with the harness since it mine was automatic and i don't have the plugs for the starter relay...
blinker_fluid
Car: 1991 Nissan 240SX FB
2000 Nissan Maxima SE
did you do the wires for the inhibitor switch? You have to jump a 2 wire harness connector at the bottom of the relay box. I forget which colors but they are heavy gauge. Heres a link to the 5-speed swap faq.
zerothread?id=99050
nismoboy54
i got everything else running right but now that reverse light is not working...still trying to figure out the wires for them
blinker_fluid
Take the two wires from the reverse sensor(furthest to the front) and connect them to the green/blue and the green/white wires on the middle plug of the relay box just like it says in the faq.
