Yeah you definitely have to drive the car for a while (including a few redlines) before you can tweak things...Meaux wrote:Heck, I backed out the IAC screw about 3 1/2 turns to set the ldle higher, and went around the block for a "testdrive". The stumble is gone, she shifts smooth, I'm sure the tires have flat spots (from sittin) causing a funny ride.
Now Im gonna try to pull the idle down...I'll check and see how many turns I get going "in". Shouldn't it be about 3-5 turns out?
Whats a quick way to "clear the codes"? Last night I had the MAF unplugged and forgot so when I raised the windows, I started the car up, now I have codes 12 and 21...
I'm feeling alot better after the "testdrive"...But I need to clear that dang ECU....
The IAC should be backed out 1.5-2 turns.
