Starting my Knock Sensor replacement today......
RobertsnewQ
I didn't do mine, but it looked very doable. Long 1/4 drive extension and wobbly socket.
PoorManQ45
It's impossible to remove the KS without removing the Y pipe hoses. It *might* be possible to do it with all the runners off, but I doubt they went through the trouble of doing that.
Oh, I was able to remove the "Y" Without cutting the hoses too.
Note, I'm the person that did the whole job for $50
Meaux
Car: 94Q45, 92Porsche 968, 72Porsche 911, 89Maxima SE, 98Honda Civic, 85F150 w/95 5.0
How the heck do you get an accurate torque on the KS without removing the "Y" pipe?
I'm gonna try and do somemore today...
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The bottom line is you gotta remoe the Y pipe to replace the hose on there anyway, so in most peoples cases if your reaplcing the hoses and KS at the same time it makes no difference.
Meaux
Well I got the "Y" pipe off with hoses, didn't need to cut anything, then the KS's, and my Rt. side sensor harness had been chewed completely in half, rodent no doubt. Both KS's were cracked...Must have happened when I didn't drive it for a couple months...During the winter when the Porsche 968 dosen't need A/C...Cleaning up the valley now and will start tomorrow on re-assembly.........and making a list for gaskets and hoses.
Ya think a local parts house would have the "Y" hoses? I'd hate to wait till next week sometime for those...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Meaux wrote:Ya think a local parts house would have the "Y" hoses? I'd hate to wait till next week sometime for those...
No way, call Joe today!
Why one always starts with more parts than one needs as Joe will take back unopened parts.
Meaux
Well, called Joe on Friday, and the hoses/gaskets came in today so I installed the knock sensors and harness, then the bypass hoses etc. Must have vacuumed a bag of sand out of the valley...So I got that part buttoned up. Not that much trouble at all, thank goodness for the KY...works with all kinds of hoses! :-)
In the AM I'll clean the Idle Control valve and start on the Intake runners...Hopefully I'll have this thing running on Friday...depends on the weather...
elwesso
2007 BMW M Coupe
Meaux wrote:Well, called Joe on Friday, and the hoses/gaskets came in today so I installed the knock sensors and harness, then the bypass hoses etc. Must have vacuumed a bag of sand out of the valley...So I got that part buttoned up. Not that much trouble at all, thank goodness for the KY...works with all kinds of hoses! :-)
No honey, I promise, im using it on the car!!!
Meaux
LOL!
Meaux
Starting on lower intake runners, and maybe this is a dumb question, but what side of the gasket should face up, the "raised" face , or the "indented" face?
Or does it even matter?
Thanks...
PoorManQ45
YES, YES, YES. That's the way to think. I went to the local comercial hose supplier and got the Y hoses for like $3. Note, the hoses I got are designed for marine exhaust applications.
maxnix wrote:No way, call Joe today!
Don't start with that.
I was able to do a COMPLETE under plenum hose job for ~$50. I replaced every hose under there! It took awhile, but I got it all done RIGHT. Now it's back together and has been running strong for about two months.
Wes, IIRC you offered me something if the Q ran for over 100 miles without a problem after the hose job. Well... It's been over 100miles
Meaux
Allright, so far so good. I got the lower intake runners on w/ fuel rails attached, and today I'll be cleaning the Plenum and mounting that.
Whats the best cleaner to clean that big part with?...I used carb cleaner on the lower runners and that took awhile. I think someone used "Oven Cleaner", but don't remember how that went...
Thanks...
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Meaux, i used some gumout carb cleaner--seemed to work fine. i debated and then decided that it wasn't worth the time to get the whole thing spotless, so i left some brown stains, but everything is smototh and clear.
of course, you could find a shop that could dip the whole thing for you, but remove all the rubber first if you do....might hurt the finish on the infiniti logo--not sure.
anyway see the other post about making sure you alighn the lower and upper runners before doing the final final. you may find it easier to do the alignment without all the spider pipes and hoses--especially the 'fat' one that goes around the #7 runner.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Soaking it in SafetyKleen bath would be best, I would think.
Meaux
Well, Katrina cut this job off, maybe I'll continue in a few days...Glad I live on top of a hill, only lost power for 7hrs., biggest problem was fueling the generator...
New Orleans...unbelievable...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Glad you and Jeff are OK. Who else is down there? Msscomm?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Hey Meaux, keep going!
maxnix wrote:Glad you and Jeff are OK. Who else is down there? Msscomm?
Jehanger in Lafayette [about 50 nw of New Orleans]. has he checked in?
elwesso
2007 BMW M Coupe
GQ Jay wrote:Hey Meaux, keep going!
msscomm is on the west coast...
Jehangir is down ther ebut hes posted since then i think
Meaux
Allrighty then, I cleaned the Plenum today and used "Easy-Off" oven cleaner. Sprayed it on inside and out, and let sit for 30seconds, hosed it off. Clean as a whistle...wish I would have used it on the lower runners...Side Note: DO NOT LET THIS STUFF SIT FOR ANY LENGTH OF TIME, IT WILL DESRTOY (PIT) ALUMINUM!!!!
Don't ask me how I know...OK, I'll tell ya'll. I sprayed this stuff on a 72' Porsche alloy wheel (expensive) and left it overnight, completely messed up the surface of the wheel. Luckily it was the spare wheel that I'll sand down and paint black.
Installing Plenum tomorrow....
DAEDALUS
Car: 1990 Infiniti Q45
Meaux wrote:DO NOT LET THIS STUFF SIT FOR ANY LENGTH OF TIME, IT WILL DESRTOY (PIT) ALUMINUM!!!!
I was wondering about that. Was planning to use in on some heads. 30 seconds, eh? I'll give it a test spray.
Meaux
30 secs. or less, it's allmost immediate. I wouldn't let it dry...I'll have to get another can for the T-Body...
Meaux
OK, finished the Plenum Removal and KS replacement.
Car started up as soon as it got enough fuel.
Idle at 850 cold
Idle didn't change after warmup....so I unplugged and adjusted the IAC to 650rpm, plug it back in...
Turn on A/C and it dosen't compensate for compressor load
rev to 2000and on deceleration allmost dies, thenpulls back up to 500rpm.
I checked the codes and I get a "21".......Ignition Signal Circuit.....Everything seems to be plugged in.......
The car has be sitting for a over a month w/battery disconnected.....At least I didn't get a KS code!
I'm tired, and I'm gonna crack open a 12pk. and look at it tomorrow....
Modified by Meaux at 3:59 PM 9/8/2005
PoorManQ45
I used to have that almost stalling problem.
It was a combination of the MAF, and faulty fuel unit
DAEDALUS
...neither of which leads to a code 21.Are you certain 21 was the only code given? So common to get a CAS error (11) along with ignition signal. The troubleshooter for code 21 consists of checking various continuities, so check your wiring once more. Does the engine run balanced, i.e., not missing any cylinders?
Meaux
DAE, I'm gettin 2 long blinks, a pause, and 1 short blink. It keeps repeating.
The car's electricial system functioned OK, meaning that when cold, Idle would be normally high and when warm would go down, and it would compensate for A/C, now it dosen't do either...seems to be running on all 8...but not as smooth as I expected it should...but not bad (no shakes or rough running) The tank is full of premeum gasoline...filled up before I started the KS work...
I reckon I need to start checkin wires at the ECM...and looking for something unplugged...
I did use a little dielectric on all the plugs...could that stuff be causing me problems?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Meaux wrote:I did use a little dielectric on all the plugs...could that stuff be causing me problems?
Not unless you put it on the gaps. Check your connections rigorously.
Meaux
OK, what are "gaps", is that the female side?
Hope you're not gonna tell me the stuff dosen't go on the contacts!!!! Yikes!!!
I've never had a problem with this stuff before...
elwesso
2007 BMW M Coupe
Yes, im bored so I made this graphic illustration
If it runs smooth but idles funky thats kinda strange.. From all the way in, how many turns is the IAC screw turned out.?
PoorManQ45
Idles rough, runs smooth.
I've had that problem before in a crown victoria. The problem was that it was running on 4 cylinders I'm serious.
Meaux
Heck, I backed out the IAC screw about 3 1/2 turns to set the ldle higher, and went around the block for a "testdrive". The stumble is gone, she shifts smooth, I'm sure the tires have flat spots (from sittin) causing a funny ride.
Now Im gonna try to pull the idle down...I'll check and see how many turns I get going "in". Shouldn't it be about 3-5 turns out?
Whats a quick way to "clear the codes"? Last night I had the MAF unplugged and forgot so when I raised the windows, I started the car up, now I have codes 12 and 21...
I'm feeling alot better after the "testdrive"...But I need to clear that dang ECU....
