Ok so today I picked up an engine from a local salvage yard for a total of $876 (includes $75 core and taxes) which includes a 90 day warranty. They didn't know the mileage of the donor but doing a check of the VIN shows it had 57k miles in 2008 and no updates after that. Then it was listed as salvage accident in like 2012. So I am guessing the mileage somewhere around 100k (60k miles in 7 years plus another 4 years gets it around there.)
They tested the compression of all cylinders and all were close to 200 psi. When I first heard that I was weary that a used engine could have really good compression but after looking at the engine I noticed a "rebuilders" tag glued to the freeze plug on the rear side of the left head (warranty void if removed). That tells me either the heads were rebuilt and replaced or the whole engine was rebuilt at some point which is why the compression was so good.
The donor car was a 2001 QX4 which was hit pretty hard in the left front but didn't impact the engine.
So I Decided to do a series of pics to document the swap for others in case they are wanting to do something similar. Today the only thing I have is a pic of the donor vehicle. Tomorrow I will take plenty of pics as I take the donor engine apart to replace all the gaskets I can while it is out.
Have parts to replace:
Upper and lower oil pan gaskets
Rear main seal
valve cover gaskets
Oil cooler O Rings and gaskets
Spark plugs
water control valve
Transfer tube gaskets (the leaky ones on the back of the heads)
Thermostat
Have already replaced these in old engine and will transfer over:
Water pump
fan clutch
radiator
So here is the donor vehicle:
