starter is good but still wont start
96NismoZ
Car: 1996 300zx, 1992 240sx
so i know the starter is good. but it wont start. i was jumping it with a screwdriver, but now that wont work either. my car makes a little electrical noise when i turn the key, but nothing happens im not aware or a relay for the starter, but there is an "inhibitor relay" on my chiltens wiring diagram. PLEASE HELP!! i hate having to roll start my car to get to and from work
slidestyle69
Car: 92 s13
Im guessin the noise ur talking about is the starter signal relay. Now even though ur starter is getting power doesnt mean its working. It could be locked up. The best and most inexpensive thing to do is beat on the starter and see if it turns over while trying to start it. I jus helped a friend with this the other day. Relay clicking, starter has power but not turning over. I pecked on the starter while he turned the key and BAM..it started
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Is the ground wire still attached to the starter solenoid?
Your solenoid may be bad.
buster415
Car: 92 s13 sr20de swapped Daily
check all connections I had a problem where it wouldnt work then some times it would just click a lot removed all connections, cleaned and re-installed problem solved.
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
If the starter and solenoid are working;In my case with the old motor the voltage drop across the battery terminals was extremely large, leaving the starter with a low amount of power.
Get new battery terminals and clean the wiring that mounts to them AKA degrease and sand the metal, then you should be good to go.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
If the voltage drop is "extremely large", then shouldn't the starter be getting alot more power? as oppose to a small drop, giving the starter a small amount of power. IDK
slidestyle69
Car: 92 s13
im gonna say since his starter is good, he says then it has to be the kanudor valve.
96NismoZ
slidestyle69 wrote:im gonna say since his starter is good, he says then it has to be the kanudor valve.
why didnt i think of this sooner?!?!?
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
Check the battery... It could be fully charged and not enough cca (cold cranking amps,) or just a bad battery. Also take a multi-meter and stick one of the leads, the red one, and put it on the positive post of the battery. With the other lead, the negative, drag it across the plastic top of the battery. If their shows to be any thing other than 0.00 then their is a problem. If above 0.01 or above it is called a parasitic drain. To get rid of this parasitic drain, simply spray any window cleaner on the battery. The amonia in the window cleaner will neutralize the acid on the battery, also clean up any corrosion on the cable ends... corrosion is not conductive. Also the starter relay is in between the fender and the battery if u need to replace the part number is 25230 89981 or RY132
Modified by coupe240sxguy at 8:08 PM 6/5/2009
ViciousCesar
Car: '90 420sx Hatch
i'm having problems with my car not starting sometimes. but i think i just found my solution. maybe yours too...
zerothread?id=242714
