Well, you want an oil pressure gauge since when you're running the car hard, you can have oil lines blow and that kinda stuff, so you want to be able to see the oil pressure drop so you can shut off the car before you do more damage.
EGT is definetly needed, as well as the Boost gauge.
Water and oil temp would be my other 2 gauges.
In my car, I am putting EGT, oil pressure, A/F ratio, Boost and water temp.
I already have the A/F ratio gauge, most people say it's not needed when you have the EGT, but it's good to be able to cross reference with the EGT.
Like I said earlier, I'm getting Haltech, I was going to have my car done at the end of the month, but now since the SR20DET is not in the car yet, and it's sitting on the shop floor, I'm going to get it rebuilt!
