2005Q45inCali wrote:the man with all the answers
Always look forward to ur responses
But yes to answer ur question... I dont mind stretched tires because I want that intimidating rear aggressive look with at least 20x11 in the back. I would most likely to a 305/30 or 305/25 in the back. I seen a CLS with 305 tires and it looked fitted so I know the Q should be able to handle it. I dont really want the car to be super low like that white Q. I just want a nice clean look with maybe a 1/2 inch to inch drop
You should be able to fit an 11" wheel in the rear of the F50, but expect to roll the fender lips, esp if you want to run any size tire over a 245. You actually don't need to go as big as 305 if you're after the steamroller look (and it's good that you can admit that your main concern is to get something that looks good for a street car, without any false pretensions about worrying so much about how the car has to perform like a race car or be driven in a capacity that you probably won't ever exceed more than a couple times a year). When you stretch a tire, you get an appearance of a much wider setup than you really have... I once had a 235 on a 10" wheel, and a corvette/camaro friend of mine swore that he thought I was running at least 295s, and he got a little jealous till I told him that they were *just* 235s. Of course the wheel fitment (offset) and stance also contributes to the overall "effect." With that said, I'd have to say that you should consider lowering the car at least 2" all around. Stock height is high enough that even a 2"/50mm drop can be considered modest, and would be totally streetable. My personal recommendation on widths: 9.5" with no more than a 235 in front, and 10.5" or 11" with no more than a 275 in back (I'd personally run a 9.5" with 235 and 10.5" with 255). Offsets... I can't say off the top of my head, but I believe these cars would want something in the low 20s range... anything less will require more fender processing than just a simple fender roll.
Wheels on the Crown are from Alstadt I belive... somewhat similar in style to the Euroline DH, but different little details
