sr22det turbo choices
karmakaze
Car: 98 240sx SE
redline will by 8000s14 sr20det with vtc still workinghks step 2 264 inhks step 2 272 out all supporting mods that are needed are done
i already have a gt2871r .86, but i think i am going to sell it and get a gt2871r .86 with the to4e .70 housing with 4" inlet or a gt3071r-wg .86 w/ 4" inlet.
if i understand correctly, the gt2871r w/to4e housing flows 44lbs (450hp) and the gt3071r flows 46lbs (475hp).
what is the spool up difference between these 2 turbos? the gt3071r is matched a bit better isn't it? or is the purpose of the t04e upgrade to better match the 2 sides of the turbo?
karmakaze
Car: 98 240sx SE
i am not going to lie. this is a bump. but is 2lbs of flow that much of a difference?
karmakaze
Car: 98 240sx SE
i bought the gt2871r .86 w/ the to4e .70 compressor housing.
sr20-thoj
Car: 89 nissan 240sx coupe
ive never heard of having different stage camshafts on each side.. what does that do anyways??
karmakaze
Car: 98 240sx SE
sr20-thoj wrote:ive never heard of having different stage camshafts on each side.. what does that do anyways??
this is actually my second staggered setup, i used to run hks 256 in step1 and 264 out step 1 and I loved it so much i decided to upgrade.
you pretty much get the starting powerband of your intake cam and the ending of your exhaust cam. its just a way to get a little bit of both worlds.
there is more detailed info in the camshaft mega-thread sticky.
pampadori
Car: 91 Nissan 240SX coupe
you bought the same turbo that you already had, but with a different compressor houseing? why not the gt2876?
karmakaze
Car: 98 240sx SE
pampadori wrote:you bought the same turbo that you already had, but with a different compressor houseing? why not the gt2876?
because i got a deal i couldn't pass up.
hpmachine
Car: '05 EVO8 + '95 240sx
Hey man I'm not sure if you drag race this thing, but if you are able to rev it out to 8000 will you be able to get through the traps in third gear? just curious.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Go with a 2871R .82 (T3 Housing). The 2871R flows too well for the small T2 housing. 20psi before 4500rpm is what i think it can be.
karmakaze
Car: 98 240sx SE
hpmachine wrote:Hey man I'm not sure if you drag race this thing, but if you are able to rev it out to 8000 will you be able to get through the traps in third gear? just curious.
on 275/60-17 and my 4.36 gear ratio @ 8000 RPM puts me @ 125mphon 265/50-17 and my 4.36 gear ratio @ 8000 RPM puts me @ 114mph
karmakaze
Car: 98 240sx SE
DrifterProdigy85 wrote:Go with a 2871R .82 (T3 Housing). The 2871R flows too well for the small T2 housing. 20psi before 4500rpm is what i think it can be.
if i was going to go t3 i would do better than the gt2871r. the gt3071r is a much better designed turbo.
DrifterProdigy85
So why not go T3 over T2? You will get more power and better spool than a T2 housing.
karmakaze
Car: 98 240sx SE
DrifterProdigy85 wrote:So why not go T3 over T2? You will get more power and better spool than a T2 housing.
Because i already have a nice bottom mount and o2 housing. I may go with a t3 latter on down the road. But I am going to see how everything works out with what I already have.
I am planning to port the wastegate hole as well as the t2 flange. I think that will make a noticeable difference.
DrifterProdigy85
Dont see how. The wastegate already holds 19-20psi perfectly solid with the right boost controller. Port/Hone the exhaust housing if anything.
karmakaze
Car: 98 240sx SE
well that gt2871r that i got has turned out to be a gt2876r. i have found mixed reviews on this turbo that completly contradict each other.
anyone running one care to clairify how it will perform?
Crowder13
wow never seen this car before, u ever come tokar kare on wednesdays
karmakaze
Car: 98 240sx SE
Crowder13 wrote:wow never seen this car before, u ever come tokar kare on wednesdays
never been there.
the car in the picture is dead. i am building my new 98 kouki and sr20det now. i should have it done in a month or 3. I am going to try my best to have it done before the meet up on the dragon.
i have a full parts list in this thread:zerothread?id=223537
the only thing that has changed is that right now i have a gt2876r .70 .86
once it gets warmer i am going to have a "help karmakaze put his car back together party" where i will provide food and beer to the 21+ people if your interested.
brandonb012
Car: 91 240sx
sounds good to me haha, you wouldnt happen to know adam hatcher or chris wayman would you?
im runnin around maryville with the primar yellow s13
karmakaze
Car: 98 240sx SE
brandonb012 wrote:sounds good to me haha, you wouldnt happen to know adam hatcher or chris wayman would you?
i don't know either of them. my name is Ben S if that rings and bells with you.
i don't think i have seen your car. only s13 i see is this white one that goes the opposite way I do when i am on my way to work.
Modified by karmakaze at 9:05 AM 3/17/2007
brandonb012
Car: 91 240sx
karmakaze wrote:
i don't know either of them. my name is Ben Spurrier if that rings and bells with you.
nah not right off it doesnt! but let me know when u need a hand puttin you car together, when it gets warm ill 21
karmakaze
Car: 98 240sx SE
brandonb012 wrote:nah not right off it doesnt! but let me know when u need a hand puttin you car together, when it gets warm ill 21
will do! thanks!
oki_bum
Car: SR Powered 1990 240SX
please post some numbers if you ever make it to a dyno. I wanna see how much power 2.2l puts out.
karmakaze
Car: 98 240sx SE
how do you guys think the HKS GT3240 (T3) would spool in an sr22? i have searched and searched but have not come up with anything concrete.
karmakaze
Car: 98 240sx SE
bump
karmakaze
Car: 98 240sx SE
double bump
DrifterProdigy85
Whats the 3240 similar to? I think an awesome spooling and good power turbo would be GT30R .63 for the SR22. SR20 hits 20psi @ 4500rpm and making near 450whp. SR22 should boost earlier and make more power.
karmakaze
Car: 98 240sx SE
DrifterProdigy85 wrote:Whats the 3240 similar to? I think an awesome spooling and good power turbo would be GT30R .63 for the SR22. SR20 hits 20psi @ 4500rpm and making near 450whp. SR22 should boost earlier and make more power.
i am not sure what its similar to. the guy who has it said that he was spooling 32psi by 5-6000 rpm. but i am waiting for him to get back to me with what his setup was and to let me know when it started to spool.
i am leaning towards to gt30r .84 if it turns out this gt3240 is not what i want. i was advised that the .64 would run out of steam with my 9k redline.
