NISMOingen wrote:Those pics are of a VE from a Primera.
I had a VET in the shop once. It does use a longitudinal transmission. (Sorry guys I know).
I've often dreamed about doing the VET in one of my B series cars, but never had the patience.
The VET varies turbo pressure along with all the nifty Valve and Ignition stuff too. What makes the VET so difficult is that the Neo-VVL uses a 3 dimensional map unlike the 2 dimensional map in the Primera NeoVVL. The primera uses RPM and Throttle position to determine lift, valve timing, and ignition timing. The VET adds in the 3rd dimension of enertial load. The VET is the worlds 1st "load-biased engine". There are pickups in the transmission that post signal to the ECU.
Using the X-Trail transmission is pretty much a necessity. I'm sure a FWD SR20VET hybrid could be done, but you are literally talking five digit numbers when it comes to the $.
Engine alone costs vary from $7-12k. (they only make a few hundred a year worldwide)
NISMOingen wrote:I suppose I could be incorrect, however there is nothing I can find in either of those websites that shows I am.
You are correct the alternate in FWD suggests a transversly mounted engine. Which, by inductive logic, one could reasonably expect all models to use the same.
Heres what I do know for certain. In the spring of last year I had a factory turbo-charged NeoVVL engine in the shop mounted to a factory longitudinal transmission. I know they were mated from the factory because we had to break the "corktar" seal when we separated the transmission.
God I do hope the SR20VET uses a transaxle. That makes the world a whole lot happier place.![]()
