s13sr20chris wrote:neo vvl(not to be confused with regular neo) is very similar to honda vtec. it is actually better.
Firstly, Honda was NOT the first to implement variable valve timing; Nissan (via Infiniti) was, atleast to my knowledge...(this has been discussed before here on NICO).
Secondly, ALL S14 and later SR20's have variable valve timing. Nissan used to call it "V.V.T.C.": Variable Valve Timing Control, I believe. They then "upgraded" to "C.V.V.T.C."; the newly added letter standing for "Continuous." This, by all accounts was the exact same thing as its predecessor, simply with a longer name.
Honda's "VTEC" has only 2 stages, or eatleast *had* at the time of VVTC's release. Nissan's version was a triple stage system and thus, inherently "better."
As for Nissan's latest reincarnation of the variable timing, I'm not sure if they somehow improved it and decided to give it a newer, fancier name, or if they just decided to update its nomenclature...
P.S. - As always, seeing as I don't actually work for Nissan, or know everything, I welcome proven corrections so if you know something I've said is wrong, please say so. I get smarter that way.
