J-Spec Tuner wrote:I have just confirmed that the SR20VET is infact FWD based.
how in the world did you confirm that? the xtrail is not fwd.
as to how much cam a turbo motor can take...
... just do what you like and prove me wrong. i am man enough to accept it if its clear. i personally believe that if you do choose to max out the cams on a turbo motor, you will encounter too much reversion and lose power. if you seek the most power, i think you will find that your idle is not rough and you dont really need the low cam.
as for porsche, they already have porsche valvetronic which is a continous system and works fine. they have variable intake system as well. they just dont use vvl with turbo. i think vvl with turbo is a redundancy.
