Wiring Specialties »
https://forums.nicoclub.com/wiring-specialties-u27774.html
Thu Sep 03, 2009 12:54 pm
I did not see you try the start signal check. If the ECU is not seeing a Start Signal at the time the key is turned on, the engine will not fire.
Check the start signal for +12V (orange wire on the dash plug). If its not going to 12V, than this should fix the problem.
Give it a go and let us know how it goes.
ThanksYury
