sr20det redtop sparkplugs
josephg15
Car: 1992 240sx
ok i searched for spark plugs but i keep coming up with like 4 different part numbers and i can't decide which spark plug to get because people have posted different part numbers...does anyone know the best ngk spark plug for my redtop...thanks
boost_creep
Car: 92 sr powered coupe,06 Spec V
i believe bkr6e is the stock plug,most ppl go for a step colder when they up the boost.like a bkr7e,or a bkr7e-ix if you want iridiums.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
NGK Iridium 7 or 8 plugs work great.
myees13
Car: 90 s13 coupe
Bkr7e (copper)part # 6097
All you have to do is go to Advance Auto Parts and tell them whichever NGK Plug code (BKR7E, BKR6E, BKR7EIX-11, ETC) and they will cross it for a stocking #, in this case BKR7E = 6097.
As stated above stock plug bkr6e, step colder bkr7e. Iridium adds the IX at the end of NGK plug code, and the -11 at the end has to do with the gap.
da40
Car: 1995 SE 240sx
Bkr7e
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
as per recommendations from both XAT and Enjuku, i use the heat range 6 at 12psi. Enjuku says only use Iridiums, XAT says only use coppers. i saw from a chemistry standpoint that iridium is far better at dissipating heat and therefore should be used whenever possible. the downside is that you can't gap them, but they really don't need gapping. as i said i'm running 12psi stock turbo and certainly no signs of the BKR6E-IX being too hot or gapped to far open.
josephg15
Car: 1992 240sx
ok thanks alot guys....hope to see you on the road.
josephg15
Car: 1992 240sx
i got the bkr7e...should they be gapped...if so what should i gap them at? thanks
boost_creep
95lstegman
josephg15 wrote:i got the bkr7e...should they be gapped...if so what should i gap them at? thanks
depends on how much boost you're running and how well it's tuned, but boost makes the biggest difference. and if you're not over 12psi you probably should be running the heat range 6 for better performance off of max. pressure.
Sr. Kev
Car: s13/u13
-BUMP-
Swapped 'em in today
After 3 test runs @ 14lbs
Works for me!
P.S
Factory gap is around .028 which works fine!
va240dude
Car: 1992 S13
I'm reviving this thread...anyone know what the cross reference # is for advance auto parts BK6RE? my advance auto parts lady can't find it
va240dude
Car: 1992 S13
va240dude wrote:I'm reviving this thread...anyone know what the cross reference # is for advance auto parts BK6RE? my advance auto parts lady can't find it
Found them at my Nissan dealership...FYI the Nissan Part # for BKR6E's is 22401-20J06
slideordie85
Car: 240sx
I am running a CA w/ a T3/T4 .50 on 10lbs w/ Stock Maf, 450cc injectors and a Mines ECU.
I put in the BKR7E's. Should I keep the gap at .28-.32?
tunermt
Car: s13 ka-t running AEM EMS v1, Gallant VR4 Running AEM EMSv2, S2k waiting for the Haltech
This old thread has all the info needed for the SR20 spark plugs what-spark-plugs-should-i-use-for-my-sr ... 49768.html
